I decided to see what I could learn about the Leaf Wetness sensor without destroying it.. I made a breakout cable from a surface mount modular jack and a 4 conductor pigtail, and inserted that between the sensor and the jack on the SIM board.
Green is ground.
Black is nominal 3VD power, on for a fraction of a second every 15 seconds or so.
Red is 3VDC from the sensor back to the SIM, presumably as afeedback indicator that there is a sensor plugged into the jack.
Yellow is proportional sensor voltage out, again, just for a fraction of a second every 15 seconds or so. Dry is ~0.04VDC, soaking wet is ~2VDC. Misting the sensor with a spray bottle of water raised the sensed voltage incrementally.
Now on to the fun stuff. I wasn't going to try to probe the gold sensor fingers once every 15 seconds to see what was going on, so I disconnected the sensor and brought it to the bench.
Then, I fed it steady 3VDC from a bench supply, and put my venerable Fluke Scopemeter across the fingers. There are 2 sets of interlaced conductive gold plated fingers.
As I have surmised in the past here, there is an AC voltage across the grid, nominal 2.6 volt square wave at ~600 Hz.
So, buried under the potting at the top of the sensor is some sort of oscillator to convert the DC power to the 600 Hz square wave, some way to measure the impedance change (probably) across the grid as moisture collects on it, and some way to convert that impedance back into a proportional DC voltage for the SIM.
