Weather Station Hardware => Other Weather Station Hardware => Topic started by: f86sabjf on February 05, 2009, 08:16:08 PM
Hi
Any favorite height for mounting this for more accurate readings or should i follow manufacturers recommendations. My unit is a novice unit an acurite 584 and it says to even keep it out of direct sun. Just curious . I did want to mount it on my tower versus hiding it somewhere. Unfortunately my tower build will probably expose it morning till 3-4pm in the summer time.
Jeff
Perhaps a stevenson enclosure near the base of the tower for the temp sensor? Height of sensor between 4 and 6 feet off the ground. :-)
Here's everything you always wanted to know about where to put your sensors, but were afraid to ask:
http://home.comcast.net/~dshelms/CWOP_Guide.pdf (http://home.comcast.net/~dshelms/CWOP_Guide.pdf)
Warning: It can become habit forming! =D>
Man, isn't that the truth! Have you hugged your kid today? Have you relocated your WXsensors today? :roll:
ROFL ouch
Thanks a million . The printer at work is going to be busy.
