But I don't see evidence of any guy wires attached to the setup so it can stand up to high wind gusts, such as during a storm. And how likely is it to stay up even when guy wired?
Here is what can happen to a properly mounted tripod when an
improperly mounted guy-wire pulls loose in a wind storm. My first indication of this was when I started getting
0 mph wind speeds (guy-wire hitting the wind cups)
The aftermath (zoom in on the roof) - the tripod is fine, the mast is buckled, the FM antenna was not damaged and it protected the disc-cone antenna & the anemometer
That problem has been corrected
New & Old bolts
The FM antenna (catching all the wind) has been lowered to the top of the tripod, I never really used the rotor, so I removed it which allowed me to move the anemometer higher.
