Author Topic: Cloud-base not shown at dashboard  (Read 1173 times)
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« on: March 23, 2017, 06:27:12 AM »
Hello there guys,
Im still puzzle about this cloud base not showing on my dashboard even when I check it using
 /cloud-base.php?uom=M&html=1 , its ok and the cloud base showing, but not in ajax-dashboard (see the image), could you help me find the source of the problem? if you view it on the web it shows like this
http://pimohweather.webutu.com/cloud-base.php?uom=M&buster=169101000
 thank you for your time.
« Last Edit: March 23, 2017, 07:07:12 AM by pimohdaimaoh »
Offline Kylo
    • Private Wetterstation Braunschweig
Re: Cloud-base not shown at dashboard
« Reply #1 on: March 24, 2017, 11:02:46 AM »
It's showing for me !
VP2 Pro Plus Aktiv, TOA Blitzortung System RED, NOAA WX-Sat, Weather Display
« Reply #2 on: March 24, 2017, 12:37:51 PM »
It is also showing fine for me at http://pimohweather.webutu.com/wxindex.php
    • PIMOHWEATHER
« Reply #3 on: March 24, 2017, 01:42:43 PM »
no, not actually, Im just restoring its temporary working cloud base for a moment but actually it has errors like the time and day image not shown on day time, only stays at night time image during in daytime.
when I remove the script cosisting time in script at line 698 and 1234,
time(); <--- deleting this will show the cloudbase image on ajax-dashboard,
the cloud base will show BUT the time in TZ is not correct and the night time image stays there without changing to day time image on daytime hrs. (Date/Time: Thu, 01 Jan 1970 00:00:00 +0000 (night)) . if you check this right now http://pimohweather.webutu.com/cloud-base.php?uom=M&html=1
youl see the DATE time is not correct and by default the cloud image will show on dashboard, however when I do restore the time(); on it, the image cloud will not show, upon checking it like this, you will see there's no error except the METAR doesnt indicated. http://pimohweather.webutu.com/cloudbase.php?uom=M&html=1 but all its dates, and day cloud image are all corrected without error but when you view it on the web inside the dashboard, only showing a small white box. so what do you think is the problem?
Hopefully you can assist me. Thanks
-Mike-
« Last Edit: March 24, 2017, 02:10:03 PM by pimohdaimaoh »
« Reply #4 on: March 24, 2017, 02:49:06 PM »
You're likely getting a warning message about the default timezone not being set and that is changing the image output.
Try changing
if ($wxSoftware == 'WU') { // Get the WUHU data
   if (!empty($tz)) {
      if (phpversion() >= "5.1.0") date_default_timezone_set($tz);
      else putenv("TZ=".$tz);
to
and
// Language settings for captions ----------------------------------------------
to
   if (!empty($tz)) {
and that will set the default timezone.  Then put back the commented out request for time();
    • PIMOHWEATHER
« Reply #5 on: March 24, 2017, 10:22:32 PM »
Try changing
   if (!empty($tz)) {
to
and
to
   if (!empty($tz)) {
Thank You for your immediate response sir, the image have been set including the default TZ  and I set it according to your instructions above, but still can't view on the dashboard instead, it only shows like this http://pimohweather.webutu.com/wxindex.php (blank image). But upon checking using "uom=M&html=1" , the cloudbase image is working and viewing fine on the web, Actually if you are looking into my wxastronomy section also, the issues are same  with the cloud-base (blank image) problem, like the sunprosa image and the sungraph image TY
Regards,
-Mike-
« Last Edit: March 24, 2017, 11:28:30 PM by pimohdaimaoh »
« Reply #6 on: March 25, 2017, 11:47:11 AM »
I think your issue is now a blank line in Settings.php before the starting <?php .. remove that blank line and your image should show up.
The Settings.php, Settings-weather.php, and testtags.php files all must start with <?php and no blanks or spaces before that, and end with ?> with no spaces or blank lines after that.
It appears that only your Settings.php has the rogue blank line before the starting <?php in the file.
    • PIMOHWEATHER
« Reply #7 on: March 25, 2017, 12:01:44 PM »
oh i see, ok im gonna fix it when i got home, im out of town till sunday, well iform you the results when i come back on sunday eve. thank you again ken. -mike-
« Last Edit: March 25, 2017, 12:08:52 PM by pimohdaimaoh »
    • PIMOHWEATHER
« Reply #8 on: March 26, 2017, 11:20:15 AM »
and of course the Pro knows it. . . . . . . . . . \:D/
Thank You Sir Ken and as what you suspected is true, now I already fix it and now it shows to the web and all its scripts working. Now I learned that any single wrong space between <? and ?> could make a great trouble too. Thank You so much and I know there will be another time regarding this which I may needed your assistance anytime soon. Thank You.
« Last Edit: March 26, 2017, 11:27:22 AM by pimohdaimaoh »
