Author Topic: Startwatch  (Read 3475 times)
Offline GreyOwl
  • Station up and running, No RH or Pressure sensors
Startwatch
« on: October 09, 2012, 12:22:18 PM »
Didn't know exactly where to put this but it also deals with Weatherlink so decided here.  After getting everything back up and running well from the lightning problem last month, I reloaded Startwatch to help deal with Wundergroung connections which has helped a bunch, but I seem to be getting an error box once in a while that locks up the process.  It is a box that pops up and says "Error, unable to create backup logfile"  When I click OK everything goes back to normal.  This seems to happen a couple of times a day so if I leave and it happens, everything just stops.
I have looked in all the settings and can't seem to find anything that controls this so am hoping someone here has an answer as to where to look.
CWOP: CW8399
KNVNORTH32
Weather Wizard III, wired
Homebuilt DFARS
Weather Link 5.9.0, serial version
Logitech 9000PRO Webcam
Offline Weather Display
Re: Startwatch
« Reply #1 on: October 09, 2012, 01:42:29 PM »
maybe the back up log file directory does not exist
or that file is locked (write protected)
Brian
info@weather-display.com
Offline GreyOwl
Re: Startwatch
« Reply #2 on: October 09, 2012, 02:54:24 PM »
Any idea as to where to even find out how to create it?  There seem to be no options in any menu.
CWOP: CW8399
KNVNORTH32
Homebuilt DFARS
Offline GreyOwl
Re: Startwatch
« Reply #3 on: October 31, 2012, 07:10:26 PM »
Don't know why this is in the VP Tools instead of WeatherLink.  I think this is more of a W/L problem than Startwatch, but it seems to be more prevalent when S/W is running.  When it happens all the W/L log files are gone and start over when I stop S/W.  Maybe I just need to finally make the jump from 5.8.0 to the latest version of W/L.  It seems to be some kind of conflict between the two.
CWOP: CW8399
KNVNORTH32
Homebuilt DFARS
