Web Weather => Weather Website PHP/AJAX scripting => Custom Website Templates => Topic started by: saratogaWX on August 05, 2016, 04:21:03 PM
If you're having an issue with one or more scripts in the Saratoga template set (USA, Canada, World) and something that was working is now not working, try running (on your website):
check-fetch-times.php?show=versions
It will show the version levels of core scripts v.s. what you have installed, and give you a link (if needed) to the update tool page with query info. Using the update tool page (http://saratoga-weather.org/wxtemplates/updates.php) will generate a .zip just for you that contains all the needed updates and quick instructions on how to install each script.
If running check-fetch-times.php?show=versions on your site just shows a series of fetch tests, then you have an old version of that software.
Download a fresh copy from here (http://saratoga-weather.org/wxtemplates/Test/check-fetch-times.php?sce=view), upload to your site, then run check-fetch-times.php?show=versions again.
You'll be glad you did, and you can save a posting on the forum or an email to me for some other issue not fixed by the above.
Best regards,
Ken
