"George/Harold... If you don't want exact accuracy, why even have a station? I want to know what the temp is at my house with the greatest accuracy possible. If I just cared that it was too hot for golf or lawn work, I'd just use the Accuweather app or watch my local news."
I have many things more worthy of my concern than a 1 deg. difference between a $80 sensor suite and a $12 tower. If I was that worried about it, I would probably buy a much more expensive set-up. And, for what it's worth, a sensor suite, like the 5in1, is a compromise at best. For example, unless yours is 33' (10 meters) above level ground with no obstructions anywhere near it, your wind speed data will be somewhat incorrect when compared to airport readings. If it is 33' high, temps will be compromised, etc. It's just the nature of the beast.
