Author Topic: How to Run US Animated Radar on Google Maps  (Read 136492 times)
0 Members and 3 Guests are viewing this topic.
Offline ELDoradoWx
  • El Dorado Weather
  • Gentoo X = Complete_Control
    • El Dorado Weather
Re: How to Run US Animated Radar on Google Maps
« Reply #125 on: October 31, 2010, 10:37:25 PM »
...anybody have a Google Maps API v3 of these routines?  Namely radar.js.
Thanks...and, again, great stuff here.
Dave.
I want work on it at some point but it's not real high on my priority list just yet. I have a long list of scripts in my todo list. I have been working on a script that writes the normal "rainfall to date" for every day of the year, along with the "normal & record highs and lows" for each day of the year. That script is up and running, I just need to clean it up a bit, then onto the next.
I was using the Wunderground high and low data via Weather Display, but the closest city I could use is a significantly different climate. I suspect that might be an issue for many of our rural area stations in the U.S..
-Danny
-root is everything
Offline stu-in-flag
    • stu-in-flag
« Reply #126 on: November 01, 2010, 10:15:03 AM »
This is a very cool script...
that I would like to incorporate into my website. I have it running as a small image on my main page,
http://stu-in-flag.net/index.php
I have been able to get it to run on an independent page
http://stu-in-flag.net/ridge.html.
But, when I try to link to a site that includes, via php include, the ridge.html file
http://stu-in-flag.net/big-radar.php
the site will literally run a single, first time. After that the ridge.html file will not animate the radar, and it appears that the css file does not function on that page. I have tried to breakdown the ridge.html code and place it in the big-radar.php file, but that ends up causing the same issue.
Thoughts?
Thanks in advance!
Offline DaculaWeather
    • North Georgia Weather
« Reply #127 on: November 01, 2010, 12:08:36 PM »
Works for me!
Offline marylandwx
« Reply #128 on: November 05, 2010, 04:21:35 PM »
I love this script!  I just found it today and have put it on my site:  http://midatlanticweathergroup.org/
The only issue is, for each marker, the bubble pops up in the same spot.  Example:  If you click on a site in VA, it will still pop up to the north of MD.
How do I go about fixing that?
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #129 on: November 06, 2010, 09:56:44 PM »
Glad that you find the script useful for your site..
The original marker code was written for 1 marker only. I would usually leave it up to the individual users to do their own research and add on their own custom code, but I added a new marker function to the map today, along with the code for 3 separate markers. You can easily add on as many markers as you like in the proper area near the bottom of the script. With my adding of 3 markers you should be able to use the same syntax samples to add on as many markers as you wish.
<script type="text/javascript">
var Clock ;
var Cycle ;
var Google;
var Helper;
var Last=  0;
var Skew=  0;
var Wrap= 10;
var Idle=100;
var Back=500;
var Radar=[];
var Ridge=["DAX"];
var Product="NCR";
function createMarker(point, text, title) {
  var marker = new GMarker(point,{title:title});
  GEvent.addListener(marker, "click", function() {
    marker.openInfoWindowHtml(text);
  return marker;
function Pause(pause)
Idle=pause*10;
Back=pause*50;
function Opacity(opacity)
for (var i=0;Ridge[i];i++)
Radar[i].opacity(opacity);
function Loop()
Helper.childNodes[i].childNodes[0].data=Radar[i].select(Last);
Last=(Last+1)%Wrap;
Clock=clearTimeout(Clock);
Clock=setTimeout("Loop()",Last ? Idle : Back);
function Feed()
var stub="http://www.srh.noaa.gov/ridge2/JSON_generator.php?callback=CallBack&amp;frames="+Wrap;
Radar[i].feed(stub+"&rid="+Ridge[i]+"&amp;product="+Product);
Cycle=clearTimeout(Cycle);
Cycle=setTimeout("Feed()",150000);
function CallBack(callback)
var stub="http://www.srh.noaa.gov/";
var pair;
var reload=[];
for (var i=0;callback.directory[i];i++)
pair=callback.directory[i].match(/([A-Z][A-Z][A-Z]|[A-Z][0-9][A-Z])/g);
reload[i]=stub+callback.directory[i];
if (pair) if (pair[0]==Product) if (pair[1]==Ridge[i]) Radar[i].reload(reload);
function Load()
Google=document.getElementById("google");
Google.style.width ="640px";
Google.style.height="640px";
GDraggableObject.setDraggableCursor("pointer");
GDraggableObject.setDraggingCursor ("pointer");
Google=new GMap2(Google);
Google.setCenter (new GLatLng(38.496,-121.672),7, G_PHYSICAL_MAP);
        Google.setUIToDefault();
Helper=document.getElementById("helper");
Helper.appendChild(document.createElement("DIV"));
Helper.childNodes[i].appendChild(document.createTextNode(""));
Radar[i]=new FrameAnimationLayerOverlay({bbox:BBox(Ridge[i],Product),size:{x:640,y:640},last:Last,skew:Skew,wrap:Wrap,name:Ridge[i]+"_"+Product});
Google.addOverlay(Radar[i]);
Feed();
Loop();
var marker = createMarker(
new GLatLng(38.496,-120.672),
"El Dorado Weather<br/>Updated: <?php echo $date?> at <?php echo $time?><br/><br/>Temperature: <?php echo $temperature?>&deg;F<br/>Pressure: <?php echo $baroinusa2dp?><br/>Rain Today: <?php echo $dayrn?>in<br/>Humidity: <?php echo $humidity?>%<br/>Dew Pt: <?php echo $dewpt?>&deg;F", 'El Dorado Weather');
Google.addOverlay(marker);
'Marker text', 'Sacramento Area');
new GLatLng(38.496,-122.672),
'Marker text', "Near Highway 101");
function Free()
GUnload();
</script>
The sample page for this code in action can be seen here: http://www.eldoradocountyweather.com/current/misc/google-maps/dax/ridge.html
-Danny
-root is everything
Offline marylandwx
« Reply #130 on: November 07, 2010, 08:49:57 AM »
Thank you very much!
Only issue I seem to have is when I change "NCR" to "N0R" it doesn't load the radar.
Offline wolfie
« Reply #131 on: December 31, 2010, 11:47:53 AM »
Dave.
Has anyone ported this over for API v3?
Thanks, looks like a great script!
Offline MaineBirder
« Reply #132 on: January 06, 2011, 04:04:25 PM »
Thank you for this great script!
I am having a problem getting the radar to show up on the map. I tried all the suggestions from the previous 9 pages of this thread and still cannot get it to show.
If it helps, I get this error in IE:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C)
Timestamp: Thu, 6 Jan 2011 21:02:55 UTC
Message: '2' is null or not an object
Line: 2487
Char: 2
Code: 0
URI: http://www.bathmaineweather.com/ridge.js
Here is the page: http://www.bathmaineweather.com/ridge.html
Thank you for any help you can provide!
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #133 on: January 06, 2011, 06:18:02 PM »
Line: 2487
Char: 2
Code: 0
Hi MaineBirder,
First off, welcome to the forum!
In your ridge.html file please remove the radar call letters [CAR] at around line#25.  [CAR] is not a valid radar station. This is what's breaking your code. Did you want the Caribou, Maine Station radar on your map? If so the call letters for Caribou is [CBW].
« Last Edit: January 06, 2011, 06:20:18 PM by ELDoradoWx »
-Danny
-root is everything
Offline MaineBirder
« Reply #134 on: January 07, 2011, 08:26:11 AM »
Hi MaineBirder,
That was the problem! Works fine now. Thank you for your help Danny, it's greatly appreciated.
I sent you an email from your web site yesterday asking about your looping satellite. Did you receive it?
Offline lakevillewx
    • http://www.lakevilleweather.com
« Reply #135 on: January 08, 2011, 12:10:54 PM »
Danny -
Thanks for the awesome contribution! I am currently tweaking and testing before launch on my site, and I am wondering where I can preset the animation speed? If I missed it previously in the thread or instructions, I apologize.
I am running my setup here:
http://www.lakevilleweather.com/google_ridge_radar/ridge.html
Regards,
Kris
Kris Pierson - lakevilleweather.com
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #136 on: January 08, 2011, 06:56:58 PM »
Danny -
Regards,
Kris
Hi Kris,
My pleasure!
NO, I don't think I ever covered the default animation speed. It's very easy to change.
Near the top of the script where it says:
var Idle=100;
The higher the number the slower the animation. This is the idle time between images as they are being animated.
-Danny
-root is everything
Offline lakevillewx
« Reply #137 on: January 08, 2011, 09:13:23 PM »
Thank you!!
Kris
Offline stormwatch
    • Carolina StormWatch Weather
« Reply #138 on: January 08, 2011, 09:53:44 PM »
OK guys before I do something very drastic here I need some help. Started working on the script several months ago but put everything aside for fall fishing and deer hunting but it's time to get back to my weather. Worked several hours last night and a couple tonight and I am getting nowhere. ](*,)
I have my goggle map (got to tweak a tad on centering) but I am not getting any radars or my "home marker" to show on the map. No precip around tonight but last night with precip around; same thing...just the map. I have tried "NCR", ("NCR") and ["NCR"] and no radar and no home marker. :?:
Any help, suggestions, ideas would be greatly appreciated!!!! The ONLY thing I have not tried I believe is an absolute path (ie. http://www.carolinastormwatch.com/goggle_ridge_radar/ridge.js) for the js paths but didn't think this was necessary. I did have the files just in my main directory but put them a sub directory (goggle_ridge_radar) to see if that would help...no go.
Link:  http://www.carolinastormwatch.com/goggle_ridge_radar/ridge_test.html
Many thanks!!
CoCoRaHS NC-BR-1
CW0803
Advanced Spotter
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #139 on: January 08, 2011, 11:36:25 PM »
Many thanks!!
Hi Tom,
You have the same sort of problem that MaineBirder had a few posts up. There is no AQK radar station. It looks like you just transposed it wrong (very easy to do). It should be "AKQ". Fix that typo and everything should be working fine for you including the marker.
I would like to mention to others that may try this script. I highly recommend adding just one radar station at a time. See if that works and then go on and add on another one.
« Last Edit: March 22, 2011, 10:49:03 PM by ELDoradoWx »
-Danny
-root is everything
Offline stormwatch
« Reply #140 on: January 09, 2011, 12:55:27 AM »
Many thanks for the help Danny!! Great script! :grin:
I can't believe that little error caused me hours of frustration; well, yeah I can. I went over and over my script and did not catch that. :oops: You are exactly correct in saying the best way to test the script is to use ONE site. For me it has to be K.I.S.S. or I always end up with one little error that ends up costing me hours of frustration.
Thanks again!!
Tom
CoCoRaHS NC-BR-1
CW0803
Advanced Spotter
Offline golfnutmdh
« Reply #141 on: March 05, 2011, 01:56:42 PM »
I am curious where/how you found the lat/lon projection data for each radar site in the ridge.js file?  I'm looking to project the conus map in a similar fashion, just lack the projection coordinates.  Thanks!
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #142 on: March 22, 2011, 10:36:51 PM »
NOAA puts the coordinates for each radar station in a .gfw world file. These files reside with the standard .gif radar files in the "RadarImg/RadarType" directory.. Such as RadarImg/N0R - RadarImg/NCR - RadarImg/NOS - etc etc
« Last Edit: March 22, 2011, 10:47:11 PM by ELDoradoWx »
-Danny
-root is everything
Offline subh
« Reply #143 on: April 12, 2011, 08:43:43 AM »
Do you have similar functionality written using Google Maps V3?
-Subh
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #144 on: April 13, 2011, 09:24:26 PM »
-Subh
Not completely. The script as is, uses some V3 features, but for the most part it is pure V2. I have no plans to update it to V3 at this point unless it breaks.
-Danny
-root is everything
« Reply #145 on: April 21, 2011, 02:48:57 PM »
How come Google Maps radar doesn't label my town on its maps even though it's the 10th largest town in Oklahoma?  I noticed it's very generous in labeling much smaller towns like Kingfisher and Hennessy.  Zooming in to enough degree does solve the issue, though.
http://stillwaterweather.com/ridge.html
« Last Edit: April 21, 2011, 03:07:49 PM by Bunty »
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #146 on: April 22, 2011, 09:02:37 PM »
I am pretty sure this was a rhetorical question. I did see an interesting observation that takes the idea a little bit further.
http://www.41latitude.com/post/611286757/google-maps-city-dots
-Danny
-root is everything
Offline Stetson1
  • Cordera Weather
    • Cordera Weather
« Reply #147 on: May 05, 2011, 01:32:47 AM »
Can someone refresh my memory, how can I get rid of the image URLs in the ridge.html? I thought I had it but can't seem to find how to remove those.
Todd
Offline ELDoradoWx
  • El Dorado Weather
    • El Dorado Weather
« Reply #148 on: May 05, 2011, 07:05:14 PM »
Todd
Hi Todd,
You can find the code to get rid of the URLs below the radar display here:
http://www.wxforum.net/index.php?topic=8377.50
It's the 10th post down...
-Danny
-root is everything
Offline Stetson1
  • Cordera Weather
    • Cordera Weather
« Reply #149 on: May 06, 2011, 12:14:19 AM »
Much thanks, that is exactly what I was looking for.
Todd
