Sorry about that. Download from the data logger to the new WeatherLink software. It would not do this before with the old data logger and that was with the guidance of Davis tech support. Communication port set TCP /ip and I am NOT using web download right now. What I was saying is previously with the old data logger when I would go into WeatherLink 5.9.0 and clicked on the download menu nothing would happen. Now with a new data logger and a new software I just go to the download menu click on Download and presto download occurs. I am assuming that when you click download its pulling from the data logger correct or am I wrong about that? That's as long as I am not setting the software to Web Download ???
Yes, that is correct. With that port setting, you are getting your download from the logger.
However, if you used Web Download, you
should be able to recover some of the historical data that is stored on your WeatherLink.com account. It appears that you are using the same WeatherLink.com station identification/login, "midnightstar1".
In any case, It's great to hear that things are now going well.
