Hi guys,
I want to ask you for some help with understanding the concept of degree days. We don´t use it in my country so Im not sure I understand it correctly.
I have read about it in Wikipedia, this is how I understand it:
First you choose a base temperature. Next, you take the average daily T and if it is above the base T, you would have 0 HDD and the difference would be the number for CDD, likewise, if the avg T is below the base, you would obviously not be cooling (i.e. CDD=0) and HDD would be equal to the difference between the base and the avg T.
So far so good.
Now looking at some of the files that are generated on some of your pages using Ken´s script, I see for example this (I used Ken´s data for May 2016):
HEAT COOL AVG
MEAN DEG DEG WIND DOM
DAY TEMP HIGH TIME LOW TIME DAYS DAYS RAIN SPEED HIGH TIME DIR
1 69.1 88.4 1:10p 51.6 6:30a 3.5 7.6 0.00 0.5 13.0 5:50p SSW
2 62.6 78.6 1:05p 47.6 6:20a 6.0 3.6 0.00 0.7 12.0 3:05p N
3 64.1 78.6 4:15p 53.6 2:10a 4.2 3.3 0.00 0.4 11.0 1:45p N
4 63.0 75.6 3:45p 55.7 4:30a 4.4 2.4 0.00 0.5 11.0 3:45p N
5 60.8 70.9 3:00p 54.5 4:45a 4.8 0.6 0.00 0.6 13.0 2:50p S
6 56.3 62.9 11:00a 50.7 11:40p 8.7 0.0 0.15 0.2 11.0 2:30p NW
7 56.7 63.9 3:40p 50.2 4:10a 8.3 0.0 0.06 0.5 11.0 2:40p ESE
8 61.5 74.6 3:15p 53.3 3:25a 5.1 1.5 0.00 0.5 11.0 5:10p N
9 62.3 76.5 2:25p 55.1 4:35a 5.0 2.4 0.00 0.8 12.0 3:45p N
10 63.7 81.1 2:55p 54.8 7:05a 4.9 3.6 0.00 0.6 11.0 3:20p N
11 62.7 78.5 2:35p 51.3 4:45a 5.7 3.4 0.00 0.5 11.0 2:55p N
12 63.1 76.0 12:35p 54.2 1:20a 4.9 3.0 0.00 0.6 11.0 3:40p N
13 60.5 73.5 2:45p 52.0 12:00m 5.7 1.2 0.00 0.5 13.0 3:55p N
14 62.3 79.2 3:00p 48.3 2:45a 6.0 3.3 0.00 0.6 16.0 5:30p N
15 63.6 77.4 4:30p 54.5 6:50a 4.3 2.9 0.00 1.0 14.0 4:40p NW
16 64.9 81.2 4:05p 49.5 6:15a 5.0 4.9 0.00 1.1 13.0 3:05p N
17 71.0 90.7 4:25p 52.0 5:55a 3.7 9.7 0.00 1.3 14.0 11:55a NW
18 73.1 91.6 2:05p 56.2 6:15a 1.8 9.9 0.00 0.9 13.0 2:25p N
19 62.2 78.3 12:55p 52.8 12:00m 5.4 2.6 0.00 1.2 17.0 4:30p W
20 57.2 67.8 2:10p 51.1 5:55a 7.8 0.0 0.00 1.8 17.0 10:55a NW
21 57.1 65.6 6:05p 48.9 12:00m 7.9 0.0 0.02 0.6 13.0 1:20p WNW
22 56.2 70.9 1:30p 45.1 5:45a 9.2 0.4 0.00 0.8 16.0 3:20p NW
23 59.2 74.0 4:50p 46.5 3:30a 7.6 1.8 0.00 1.1 16.0 4:10p NW
24 59.9 73.7 4:45p 49.8 2:55a 6.3 1.1 0.00 0.6 16.0 3:45p NW
25 54.6 57.2 8:15a 54.2 2:45a 3.6 0.0 0.00 0.0 5.0 12:05a WNW
Now, what is confusing to me is that based on my understanding of it, a day has a particular avg temperature. If it is above the threshold you would have the difference between the base T and the actual value as cooling deg day, likewise, if the average is below the base temperature, you would have the difference being equal to heating degree days. Now based on this, obviously it is either that or that, the other one would be zero (if it is below the base, you are not cooling, if it is above, you are not heating). So where do those numbers in the above file come from. For example, on the 1st, it shows HDD as 3.5 and CDD as 7.6. The mean is 69.1. So shouldnt it be 0 HDD and 4.1 for CDD? even a conversion to C wouldnt help, that would be multiplied by 1.8, which in case of 4.1 is 7.4, not 7.6 and still, why is HDD simply not 0...
and my next question, is this always calculated in deg F? Because in deg C the differences would be different
