Hi, first post!
We have frequent power cuts and dropsouts here in the Highlands.
A significant problem for me was that the console of the WS-1001 clones does not use batteries, so that a power cut creates gaps in the data.
An external rechargeable battery is the solution. It needs the following capabilities:
1 It doesn't have to be switched on to work.
2 It has the right voltage for the console - 5V at 1A.
3 It has enough capacity for several hours.
4 It has passthrough charging, that is, it can power a device and charge itself at the same time. Beware! Not all batteries can do this and this is the hardest part to satisfy.
5 It has to recharge faster than its output to the console, in other words we need to charge it at greater than 1A, so we need a 1.5-2A charger.
Research lead to the three items below, all quality products and well priced.
I've been running this setup for months and it has survived many power cuts keeping the console running throughout.
Portable Charger RAVPower 16750mAh Power Bank External Battery Pack with Most Powerful 4.5A Output and iSmart Technology
https://www.amazon.co.uk/gp/product/B00OJXVDAUAnker USB Charger 24W 2-Port USB Wall Charger and PowerIQ Technology
https://www.amazon.co.uk/gp/product/B016LPTBO8CY USB 2.0 Male to Right Angled 90 Degree 3.5mm 1.35mm DC Power Plug Barrel 5v Cable 80cm
https://www.amazon.co.uk/gp/product/B00YA1J4XOPlug the Anker charger into the mains socket.
Plug USB lead into a socket on the Anker USB charger and the other end into the 5V In socket on the battery.
Plug CY USB lead 3.5mm plug into the console and the other end into 2.1A socket on the battery.
I managed to velcro the battery onto the console stand and put the excess wiring behind the stand.
Hope this helps others in my situation.
