Hey -
Starting on line 49 try adding the following code to your wxgrahic.php page. The basic code remains the same with exception of the changes for allowing curl.
//get adisory information
if ( ! isset($_REQUEST['warnzone']) )
$_REQUEST['warnzone']="YOUR WARN ZONE";
if ( ! isset($_REQUEST['warncounty']) )
$_REQUEST['warncounty']="YOUR COUNTY ZONE";
if ( ! isset($_REQUEST['warnlocal']) )
$_REQUEST['warnlocal']="City+State";
//You can pass data to this script with:
// http://www.carterlake.org/testadvisory.php?warnzone=XXXXXX&warncounty=XXXXXX&warnlocal=YOURCITYNAME
//Where the zone is your zone and the county is your county and location is your location
//using pluses in place of spaces
$warnzone = $_REQUEST['warnzone'];
$warncounty = $_REQUEST['warncounty'];
$warnlocal = $_REQUEST['warnlocal'];
$curl = curl_init();
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl, CURLOPT_USERAGENT, "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.6) Gecko/20070725 Firefox/2.0.0.6");
curl_setopt ($curl, CURLOPT_URL, "http://forecast.weather.gov/showsigwx.php?warnzone=${warnzone}&warncounty=${warncounty}");
curl_setopt ($curl, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($curl, CURLOPT_HEADER, true);
$html = curl_exec($curl);
curl_close ($curl);
//import NOAA Advisory info
//data can be altered by changing the zone and county numbers
//Target data ends up in $targetwarn and $targettext[0]
//$html = implode('', file("http://www.crh.noaa.gov/showsigwx.php?warnzone=${warnzone}&warncounty=${warncounty}"));
//Get the advisory headers and put them in an array
preg_match_all('|<h3>(.*)</h3>|', $html, $headers);
$warnheaders = $headers[1];
//Get the advisory text and put them into an array as well
preg_match_all('|<pre>(.*)</pre>|Uis', $html, $headers);
$warntext = $headers[1];
//If there is more than one advisory, we need to set its priority
if (count($warnheaders) >= 1) {
$i = 0;
$flag = 0;
//First, around here tornados are the biggest danger. A warning is critical information.
//Display this one first no matter what!
while ($i < count($warnheaders)):
if (preg_match("/Tornado Warning/i", $warnheaders[$i])) {
$targetwarn = $warnheaders[$i];
$targettext = $warntext[$i];
$targettext = explode("$$",$targettext);
$flag = 1;
break;
$i++;
endwhile;
//Next if there are none of the above found. Display the first warning message.
if ($flag == 0) {
$i = 0;
if (preg_match("/Warning/i", $warnheaders[$i])) {
$flag = 1;
break;
$i++;
endwhile;
//Next if there are none of the above found. Display the first watch message.
if ($flag == 0) {
$i = 0;
if (preg_match("/Watch/i", $warnheaders[$i])) {
$flag = 1;
break;
$i++;
endwhile;
//Next if there are none of the above found. Display the first advisory message.
if ($flag == 0) {
$i = 0;
if (preg_match("/Advisory/i", $warnheaders[$i])) {
$flag = 1;
break;
$i++;
endwhile;
//Next if there are none of the above found. Display the first statement message.
if ($flag == 0) {
$i = 0;
if (preg_match("/Statement/i", $warnheaders[$i])) {
$flag = 1;
break;
$i++;
endwhile;
//Next if there are none of the above found. Set the advisory to default message.
if ($targetwarn == "Hazardous Weather Outlook") {
$targetwarn = "NO CURRENT ADVISORIES";
$targettext[0] = "THERE ARE NO ACTIVE WATCHES, WARNINGS OR ADVISORIES";
} else if ($targetwarn == "No Active Hazardous Weather Conditions Found") {
} else if (empty($targetwarn)) {
} else if ($targetwarn == "Short Term Forecast") {
if ($targetwarn <> "NO CURRENT ADVISORIES") {
$warnlist = 'ALL CURRENT ADVISORIES:';
for ($i = 0; $i <= count($warnheaders); $i++) {
$warnheaderplus = preg_replace( '| |', '+', $warnheaders[$i] );
$warnlist = $warnlist . '<br><a href="http://www.crh.noaa.gov/showsigwx.php?warnzone=' . $warnzone. '&warncounty=' . $warncounty . '&local_place1=' . $warnlocal . '&product1=' . $warnheaderplus . '" target="_new">' . $warnheaders[$i] . '</a>';
Hope this helps
Greg
