Author Topic: Uploading .csv backup  (Read 924 times)
Offline pgermond
« on: January 10, 2017, 03:06:11 PM »
Is it possible to upload the save data in a .csv file to the ws-1001 console?
Offline pgermond
Re: Uploading .csv backup
« Reply #1 on: January 10, 2017, 03:48:12 PM »
Please disregard. Ambient says NO.
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
« Reply #2 on: February 09, 2017, 07:21:50 PM »
Ambient put you in error. .csv Files with measurement data are created on your storage card (SD) in the directory EasyWeather when doing backup. For these files you can access through your SD card or USB cable. You can edit the file in Excel and load it on (SD). Only, I do not understand why?
The station (console) stores in its memory the data-to-date directory EasyWeather / Database (extension .dat) - example 2016.dat or 2017.dat. These files can not be modified by the entrance to them - unfortunately.
« Last Edit: February 09, 2017, 07:50:31 PM by Rychu »
Offline gillesroszak
  • Qui trop écoute la météo, passe sa vie au bistrot.
    • meteokerbach
« Reply #3 on: May 17, 2017, 03:43:21 PM »
HI,
Go to this link http://www.meteo-gujan.org/Visiteurs/
And download the file named   http://www.meteo-gujan.org/Visiteurs/EditHistory4.0.ex_.
don't forget to rename it as .exe
With this soft you can open and modify the .dat files and export them as .cvs
« Last Edit: May 17, 2017, 03:46:22 PM by gillesroszak »
