Author Topic: HOMEWEATHERSTATION Dashboard template  (Read 39189 times)
Offline badgemaker
Re: HOMEWEATHERSTATION Dashboard template
« Reply #225 on: May 19, 2017, 06:13:41 PM »
thought i had it working but wasn't updating from cumulus I am running cumulus mx and in the data field have put http://www.dreamhills-2.com/weather the realtime.txt file is in that directory
Offline badgemaker
« Reply #226 on: May 19, 2017, 06:52:08 PM »
http://www.dreamhills-2.com/weather/index.php
if i go here then the template is showing with the right info if i just go to
 http://www.dreamhills-2.com/weather then the standard cumulus page appears but weather is not updated
Offline gus
    • Halethorpe Weather-Watch
« Reply #227 on: May 19, 2017, 07:49:10 PM »
http://www.dreamhills-2.com/weather/index.htm
delete the index.htm file to fix the problem
.htm trumping .php
Davis VP2+, LabJack w/temp sensors & 1-Wire lightning counter on AMD Athlon IIx2 220, 4GB, Windows7
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #228 on: May 19, 2017, 07:58:36 PM »
I think he must also stop the Cumulus updates otherwise if you just delete it, as soon as the update time comes, Cumulus will re-upload it. If you still have Cumulus uploading index.htm then you need to stop this in Cumulus.
Offline badgemaker
« Reply #229 on: May 20, 2017, 05:18:22 AM »
hi guys looks like i have most of it working but not all the far right says offline and the weather underground isn't showing i have put the weather underground station id in and also the api key(is this the password key for the station or the api key you get from the developer part of wu
Offline weatherist34
  • its just my hobby
    • Sinanoba Istanbul Home Weather Station
« Reply #230 on: May 20, 2017, 05:39:37 AM »
Hello
Your API is from the developer area it is the key example 098644671abcde12
Brian
Offline badgemaker
« Reply #231 on: May 20, 2017, 05:46:26 AM »
cheers brian seems everything ok now love the template how do i stop cumulus uploading the index.htm file so if someone goes to http://dreamhills-2.com/weather it goes to the template and not to the cumulus basic page i know its in the cumulus somewhere
« Last Edit: May 20, 2017, 05:49:42 AM by badgemaker »
  • its just my hobby
« Reply #232 on: May 20, 2017, 05:50:12 AM »
cheers brian just wait now to see if it sorts itself out
Hello
It will be fine just wait a few days for your chart data to build up I'm guessing that's a new wu station just setup . Hence no data for month or year but daily is working from 10am your time today. All looks good have fun..
Brian
  • its just my hobby
« Reply #233 on: May 20, 2017, 05:56:17 AM »
I didn't see your edit , I don't know may be ask over on the cumulus forum , I don't use it so would have no idea but I'm sure they will know here http://sandaysoft.com/forum/index.php
Brian
Offline nitrx
    • Apeldoorn-Oost The Netherlands
« Reply #234 on: May 21, 2017, 04:24:33 AM »
Go to  Settings => Web/FTP settings  and disable all the options and delete the index.htm from your server with a ftp-client.
Ron
Cumulus software
Apeldoorn NL
http://www.apeldoornmeteo.nl
several languages
  • its just my hobby
« Reply #235 on: May 22, 2017, 05:43:39 AM »
preview of upcoming release  see screenshot below and its basically running at https://weather34.com , may not appear for a few weeks due to ramadan starting here and I kind of disappear for a month but i have been asked many times so here is a solution that allows you to choose either pre configured modules or build your own if you are experienced in web design/code.
simply it will use easyweathersetup.php and you just select from the drop down choice in any of the the 4 positions which one you want show in a particular position. it doesn't get any easier than this
literally as example
position 1 = indoor.php
position 2 = clock.php
position 3 = earthquake.php
position 4 = alerts.php
there will be a selection of small preconfigured modules to choose from and a blank module where you can design your own using whichever code you wish.
this will expand across the whole of the temple in the future. so each module will be swappable for positions , there will be eventually 13 positions to choose and use.
brian
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #236 on: May 25, 2017, 01:54:19 PM »
Thank you Brian for the latest update with new Design and features!
Dashboard V3.4-X4
http://nyweather.net
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
  • its just my hobby
« Reply #237 on: May 25, 2017, 01:59:23 PM »
Dashboard V3.4-X4
thanks
just hang in there for a few hours i will upload a updated version with a few fixes,additional things and tidied up some of the new modules , im just clarifying some additional options to work with weather display software . ive fixed the 24/12 our clock option, cleaned up the earthquake module , added some other extra modules . smarter css stripped all the stuff not needed keeps all running nicely.
just watch for the date change on the info page then it will all done as Im away for a few weeks after sunday.
glad you like it .
brian
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« Reply #238 on: May 26, 2017, 01:09:57 AM »
I Guess its time to update mine, Thanks in advance brian
-Mike-
My test Site:
http://pimohweather.webutu.com
My CWOP ID: EW0758
  • Weather Hobbyist
    • Spring Hill
« Reply #239 on: May 26, 2017, 03:46:57 PM »
Dashboard V3.4-X4
thanks
glad you like it .
brian
Yes, the new options on the main page are very nice.
I did see the new update and upgraded to that.  Much better now, I see the clock and barometer is fixed.
As a note I have edited the WXCHARTS link from menu (WXCHARTS.php) and added my own links which is nice but I'm not sure if many know they can do this too.
http://nyweather.net/wxcharts.php
Thanks again Brian.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
    • PIMOHWEATHER
« Reply #240 on: May 27, 2017, 12:41:46 AM »
Dashboard V3.4-X4
thanks
glad you like it .
brian
Thanks again Brian.
Hello,
many knows to add the wxcharts nut I didnt add mine since all my charts are already at the main site of mine, its ok for me not to add the charts at least Brian give it a way to us modify it if we want to link the charts, this time Bravo brian. . . bravo  =D>
My test Site:
My CWOP ID: EW0758
Offline Bashy
    • Suffolk Weather
« Reply #241 on: June 01, 2017, 02:40:48 AM »
Hi, using the latest version, is it possible to use my own data for the current sky conditions please? i was able to in one of
the early versions, this one but the menu no longer works, so i added the new version here, but i believe its using WU for
the current conditions? thank you.
Kind regards
Bashy
  • its just my hobby
« Reply #242 on: June 01, 2017, 05:38:02 AM »
hello
can you please send me a copy of your old currentconditions (email) i cant remember what the code was , i do recall doing something a while ago.
if you can send it via email as I am on a limited internet via phone and forum access at times is slow, not a forum problem! my problem.
saturday i have an update to issue so i can add it into that and you can download saturday morning the download date will reflect it has been updated.
https://weather34.com/homeweatherstation/
few changes nothing major just removed some of the translated terms as it is getting tedious having to design around different word length phrases in other languages . see screenshot to see the minor changes .improved earthquake layout minor visual improvements for those who monitor.further weatherflow hardware lightning implementation now records, yearly total for chart display ,daily lightning running totals.
brian
Offline kokos1405
« Reply #243 on: June 01, 2017, 05:42:36 AM »
Hallo Brian.
I have updated to the latest version and I have problem with rain stats only. It shows them like inches.
Could you check it?
https://meteotimb.eu/tablet
Sent from my iPhone using Tapatalk Pro
  • its just my hobby
« Reply #244 on: June 01, 2017, 05:56:03 AM »
hello
will be fixed for saturday i know what the issue is .
question where are you your coordinates 24.7687 35.070782  greece or egypt ?
i only ask i was on KOS yesterday 36.7938692 26.57619
« Last Edit: June 01, 2017, 05:57:34 AM by weatherist34 »
Offline kokos1405
« Reply #245 on: June 01, 2017, 06:22:13 AM »
It's Greece at South Crete.
Offline Bashy
    • Suffolk Weather
« Reply #246 on: June 01, 2017, 12:52:11 PM »
Thanks Brian, i have emailed you, no rush but i will remind you at Xmas should the need arise ;) :D
Kind regards
Bashy
Offline nitrx
« Reply #247 on: June 02, 2017, 11:40:13 AM »
hello
Hi Brian when I chose for Imeperial Units instead Numeric I get a higher firedanger risk , I assume these percentages must be the same ?.. url - http://apeldoornmeteo.nl/pws/index.php?lang=en
Thanks Ron
Ron
Cumulus software
Apeldoorn NL
several languages
  • its just my hobby
« Reply #248 on: June 02, 2017, 01:33:43 PM »
NEW VERSION 3.4-X4 (FRIDAY 2ND JUNE 2017)
  - FIXED issue with rain charts conversion
  - Fixed firerisk showing more than 100%
  - Added new easyweathersetup option for weather display users to use current weather icon and description the clientraw.txt file
  - New SVG icons for weather display users using the current icon from clientraw.txt
  - Top modules cleaned up layouts and better earthquake layout
  - Trend barometer/temperature values moved and removed translations due to phrases vary in length and create havoc with design layout
  - FULL UPDATE IS REQUIRED DUE TO NEW OPTIONS IN EASYWEATHERSETUP.PHP
brian..
« Last Edit: June 02, 2017, 02:03:03 PM by weatherist34 »
  • its just my hobby
« Reply #249 on: June 02, 2017, 01:54:35 PM »
hello
Thanks Ron
Sorry Ron
I missed this if you don't mind will have a look at it next week .
Brian
