Author Topic: Pinout for T/H sensor (7346.070) using Sensirion SHT31-LS Arduino library  (Read 521 times)
Offline mutton
Hi All,
Having some issues getting a library working on Arduino using SHT31-LS (https://github.com/HydroSense/sensirion)
I have bought a cabled VP2 and converted it to LoRaWAN, and the SHT31-LS sensor is the last thing to work out.
The sensor has White Blue Green and Yellow cables which should somehow correspond to Vcc 3.3v, Ground, SCL (Clock) and SDA (data).
I read on another post here that it was Vcc (Yellow), Ground (Green), and then not sure about SCL and SDA.
That combo doesn't seem to working and I don't want to blow it up.
Anybody got an idea about wiring for this - or even past ones SHT15 etc that may give a hint.
cheers
mutton
« Last Edit: July 08, 2019, 05:25:36 AM by mutton »
