I hadn't realized until I dug into it deeper that, apparently, the UV data that an Oregon Scientific UVN800 can provide apparently isn't an especially good proxy for a more on-point direct solar radiation measurement. Also, I hear OS doesn't make an add-on solar radiation measurement device.
So, what are the alternatives? I've read about the solar-in-a-jar device. However, rather than start yet another project, I'd prefer something a bit more off-the-shelf that "just works".
Which other vendors have something wireless for measuring solar radiation that works in the 433Mhz range?
I'm using an RFXCOM to read the wireless data, so I'm somewhat brand indifferent as to which sensor I use as long as it transmits close to the neighborhood of 433Mhz.
Naturally, I am aware Davis has a solar sensor (model 6450). However, getting an entire Davis setup (as nice as I'm sure it would be) just to get solar radiation data is overkill. Short of that, would there be an easy way to acquire the data from a 6450?
I'll keep searching, but I'm hoping many others have already blazed the trail and can point the way.
Any suggestions would be welcome.
