Author Topic: wxbuoys.php error when links are clicked  (Read 555 times)
« on: June 17, 2018, 02:21:43 PM »
Although this used to work fine, now I am getting an error in the embedded iframe as follows when I try to click one of the buoy links.
Blocked by Content Security Policy
This page has a content security policy that prevents it from being loaded in this way.
IceDragon prevented this page from loading in this way because the page has a content security policy that disallows it.
I tried the IE/Edge browser and I get a similar message. My older Firefox on the Linux box gives a blank white iframed page.
Yet, when I tried some other buoy pages from other WxForum members, theirs seem to load fine. (though they look a bit different and open a new tab, not an iframe)
I even located the buoy files in the root directory instead of /buoy/ like I had it, to no avail. I used the latest from saratoga (was newer than what I was using) and it didn't change this behavior.
Here is the page in question: http://rogerscityweather.com/wxbuoys.php
Thanks for any help on this. Is there a newer, differently structured buoy php file? I checked for updates and only found this: https://saratoga-weather.org/scripts-buoy.php
« Last Edit: June 17, 2018, 03:12:36 PM by miraculon »
Offline wvdkuil
  • Wim van der kuil
Re: wxbuoys.php error when links are clicked
« Reply #1 on: June 17, 2018, 03:05:24 PM »
Thanks for any help on this. Is there a newer, differently structured buoy php file? I checked for updates and only found this: http://
Your version is up-to-date and works exactly the same as the other ones you see around.
Just check it as  a stand-alone page: http://rogerscityweather.com/buoy/buoy-data.php
Clicking a buoy will display the http://www.ndbc.noaa.gov/ page for that buoy  ON TOP of your page.
Buy putting it in an iframe  the http://www.ndbc.noaa.gov/ should also be displayed ON TOP of your page, but that would mean in an iFrame.  And ndbc.noaa.gov does not like that, as do a lot of others nowadays.
You should make a normal page without an iframe and then it should work.
or you should modify buoy-data.php V1.18 24-Feb-2015 and add at two places (for map and table) a target="_blank" to the href, at lines 467 and 856
Wim
« Last Edit: June 17, 2018, 03:13:13 PM by wvdkuil »
« Reply #2 on: June 17, 2018, 03:13:42 PM »
OK, thanks. I'll try reworking the page soon to get rid of the iframe.
« Reply #3 on: June 18, 2018, 10:35:52 AM »
After a lot of fiddling around, I finally settled on changing to a php include, commenting out the iframe:
<!--<iframe src="http://rogerscityweather.com/buoy/buoy-data.php?show=normal" width="660" height="750"></iframe>-->
<?php include("http://rogerscityweather.com/buoy/buoy-data.php");?>
Although it finds the buoy-data.php inside the /buoy sub-directory, it was missing the arrows.
I fiddled with this, trying to get it to recognize the /buoy/arrows directory:
  $windArrowDir = './arrows/'; // set to directory with wind arrows, or
//                        set to '' if wind arrows are not wanted
//                        the program will test to see if images are
//                        available, and set it to '' if no images are
//                        found in the directory specified.
//                        // used for rotating legend display :
to no avail. There must be some reason it is trying to go to the root html directory instead of looking in the /buoy subdirectory, but I am going to stop fighting it for now. I copied my arrows directory to the root and they started showing up. It seems to be working with my cobbled mess.  ](*,)
In a previous panic, placing the huronbuoys2.gif file in the root directory also, where it was originally in the /buoy sub-directory. To try to clean things up, I deleted the root copy leaving the one in /buoy. That broke the page. I recopied it back to the html root directory and it started working again. Maybe this is related to the arrows directory issue.
Even a blind squirrel finds a nut every once in a while...
