Make sure the configuration, everywhere, is VP2+ (plus). That includes the console, and....
For the console, the manual says:
The data I want to see, such as solar radiation, soil moisture, or Temp 2 does not display.
Why?
All optional sensors must be enabled in the Station Configuration dialog box before
the data will be displayed in WeatherLink. If you are not seeing data from a sensor that
is installed in your weather station, be sure check the Station Configuration in the
Setup Menu and make sure the sensor has been selected.
Assuming you're talking about WeatherLink.com, I think there's a configuration setting.
See this previous thread:
http://www.wxforum.net/index.php?topic=16262.0
