I would keep everything the same. to move to the VP2 Plus, all you do is add solar and uv sensors. put in the sensor shelf in back of the transmitter(in the front) as Davis and figured out that there is enough of a lip on the rain collector to cast a narrow but significant shadow on the sensors.
I would guess that in your software, you then indicate in the settings you have a solar and uv sensor.
