I need some advice from anyone on here that users Godaddy's Classic Linux server and has since moved over to their CPanel Shared Hosting Plan. I have problems with my cron jobs stop working every few weeks (yes it's a Godaddy server problem) it involves the hosts resetting the cron part of the server to get things working again. This can be a pain, everything works for a few weeks, then stops, they have to reset, then everything works again. After speaking at some length about the CPanel hosting was told that if a user of the shared Cpanel over users the server in some way it will effect the other users - something I don't want - So what do you think ?
Is it worth the changeover ?
I know that the server I'm currently using is old according to Godaddy, but they won't make the change for me, figures, they suggested setting up another domain using the CPanel and transferring the website over to that, but at the same time keeping the original one intact, incase of issues, then dropping the original site once the Cpanel server is fully up and working. Good idea in mind, not so practically, am I moving over for a good reason - namely have everything running as it should - or am I taking on other troubles - ie everything working good but at a reduced speed amd open to crashes from other users on the Cpanel.
Any advice which either way I should take would be awesome.
Thanks in advance.
Nick. dw7240.com.
