Author Topic: WS-1400 and ObserverIP progress  (Read 1156 times)
Offline dolfs
« on: March 19, 2017, 01:51:55 AM »
As indicated I have been working with Ambient and their engineers to fix some further issues in the ObserverIP firmware. I am currently testing a newer version, but waiting on a list of items fixed. One thing I know has been fixed is that if you do not configure a stationID and/or password, it was still attempting to upload to WU (reported by me earlier). That is no longer happening.
During my testing I also finally spent some time on an issue that has been bugging me for a long time. The issue is that when the units are set to F (as opposed to C), any calibration temperature offsets entered are not applied as entered. Entering an offset of 0.1 results in 0 as applied offset, entering 0.2, or 0.3 applies 0.1, 0.4 or 0.5 applies 0.3, and so on. The pattern is not completely regular, but I have found the explanation and communicated this as a bug report to Ambient. It basically boils down to the offset internally being stored in C with only 1 decimal and computations using truncation and not rounding. If you are working in C you will not experience similar issues.
Similar issues also exist if your pressure units are anything other than hPa and you desire a pressure offset.
So far, but this is very time limited in scope, I have not experienced the indoor pressure dropouts we've been seeing since early March. I also noticed some people discussed the indoor unit needing to be about 10ft away from the ObserverIP. Mine has always been 25+ feet away and it has never created a problem.
So, at the very least I would hope another version comes to me for testing with these issues fixed as well.
--dolf
Ambient WS-1400-IP + MeteoBridge
Offline greatg
Re: WS-1400 and ObserverIP progress
« Reply #1 on: March 19, 2017, 11:27:37 AM »
Good to here that things are progressing! I'm hoping the sporadic data reporting and constant rebooting of the Observer will be solved?
Offline dolfs
« Reply #2 on: March 23, 2017, 05:03:56 PM »
I have been testing a newer version that now seems to have been released (without letting me know): 3.1.6. I have not been able to confirm through my testing (too short a period) that all is fixed.
--dolf
Offline greatg
« Reply #3 on: March 25, 2017, 11:38:20 AM »
Been running 3.16 since yesterday evening. The graphs are no longer sporadic, but my pressure reading still are (see attached) [ You are not allowed to view attachments ]
Offline dolfs
« Reply #4 on: March 28, 2017, 03:25:52 AM »
Mine is fine. Time is off though!
--dolf
Offline dolfs
« Reply #5 on: March 28, 2017, 05:37:41 PM »
And the plot thickens... If your clock is off, and you are not making uploads to WU, or if your password is wrong, then the explanation (but no solution) is part of the below.
You may recall that I have left the WU stationID and password blank as I upload via a MeteoBridge instead. I reported in another thread that, nonetheless, the ObserverIP still contacts WU with a repeated (and failing) data request. After I reported this, the newer 3.1.6 firmware was modified to no longer do this in such a case.
Then I investigated that time issue. Contact with Ambient was very disappointing. By way of background: I have been reporting quite a few bugs in the product to them over the past 3 weeks, and in some sense over 2 years. None of these, except one, have been fixed, and I have been given signals they won't be.
Anyway, in this latest exchange I mentioned that I saw no way to configure NTP on the ObserverIP (so it would have the correct time), nor did I inspect any NTP traffic from the ObserverIP when I inspected network traffic. The response was that it does not use NTP, but rather takes the time from wunderground.com. The latter, of course, requires that requests to WU are being made, which I am not!
So did some more experiments and was able to confirm:
  • The response to an upload request to WU includes a "Date" header in the response
  • The time in there is, of course, nowhere near as accurate as any NTP supported time would be, and is merely reflection of what WU thinks that time as, further affected by network delays etc.
  • This time is parsed to set the time in the LiveData screen, but only if the request to WU responds with the word "success"
  • There seems to be an issue with the TCP/IP software stack in the ObserverIP causing every request packet to be retransmitted 6-8 times, resulting in unnecessary network traffic, up to 8 times more than needed. It also means that WU servers are being bothered with these re-transmits as well.
So, to get the time correct I have to make successful requests to WU, but I cannot use my stationID because I already upload data to it from MeteoBridge. That data has been processed after receiving from the ObserverIP and I could not send the raw ObserverIP data to the same station. I created a "fake" new station for testing, and confirmed time is now taken. I still do not want to pollute the WU "space" with a "fake" weather station, so I tried setting an incorrect password, hoping time would still be taken (as the time is present in the response), but it is not.
I was told that the product was only every designed, and sold to work with Wunderground and I was using it outside of spec and I should provide my own "time solution" to the applications that use the data from the "Live Data" screen (where time is clearly incorrect). Clearly, Ambient is not interested in fixing.
Nevertheless I reported the retransmit issue and suggested they take the time, even if the response reports an incorrect password. While I would still be forced to accept all the unnecessary traffic (in my case) just to get the correct time, it would be a workaround. The real solution, of course, would be implementation of NTP client software. We'll see what happens.
--dolf
