Exactly!
One dictionary defines accuracy as "the degree to which the result of a measurement, calculation, or specification conforms to the correct value or a standard."
Now, the "correct value or standard" for wind measurement
at the stated location of my weather station would be what would be measured at a 10-meter height above
level, grass-covered terrain,
unobstructed and
unaffected by any nearby objects like a house, roof, trees, etc. etc.
That's not likely to happen for most of us. In my case, I live on a lot with lots of slope, with uphill neighbors and lots of trees. Here are some pictures:
http://www.thecoys.net/lsview/1420_Valley_Forge_Dr.htmlSo, we do what's most
practical under our own circumstances - the best we can do - and then, for future readings, that's where our wind measurements were made, over time.
Footnote:
And
"placing anemometer somewhere else and using long range transmitters with Davis stations. If you have a friend, family member with good location this is always possibility"
certainly isn't an accurate way to measure wind at the location of the rest of the weather station.
