AZmonsooncats:
All it takes to create phantom lightning strikes is a poorly shielded florescent light ballast. Our office lights cause a false "hit" with a range of 200 miles to the NW everytime they are turned on or off.
The other major source of noise is AC power lines -- If the Boltek antenna cable is allowed to come in contact with a typical AC power line, this will generate all kinds of false detections and noise.
Looping the Boltek antenna cable into multiple tight coils will also cause problems -- We discovered this can lead to an increase in 180-deg lightning strike reflection errors [this drove us nuts for months until we figured this out].
Software plays an important part too -- We operate two Boltek Stormtracker systems. One is tied to a computer running "NexStorm", the other is running "Lightning 2000" from "Aninoquisi" :
http://www.aninoquisi.com/lightning2000.htmWe get fewer false strikes and far less bearing / range errors with "Lightning 2000" [than with NexStorm]. "NexStorm" though connects us directly to the StrikeStar network [which uses lighting reports from multiple Boltek stations to filter out false "hits"].
Cheers!
Patrick R. Mullen
Dir. of Engineering
Mullen Scientific Software
1686 State Route 69
Parish, NY 13131
Office: (315) 625-4660
Cell: (315) 314-1234
prmullen@dreamscape.com [Office]
prmullen@hughes.net [Backup]
