I am in the same situation, but with the PCI board.
So far, I've not found a way, due to I believe the way the software gets data from the sensor. Of course I could be wrong.
It would be nice if the sensor had a hardware register that was filled with the current strike data, and as many softwares as wanted to run would be able to read the data. As it is now, it appears, again I could be wrong, that the software running talks to the hardware with requests which would necessitate that only one software package can be in charge.
Please let us know if there is a way and you find it.
