Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
My station is FARS equipped.
I only *half* agree -- I neither trust nor use their temp (grossly different locales) only their dewpoint, which is (usually) very consistent over relatively large geographic areas.
See for yourself, "...rocks and sand..." (wink,wink)
Quote from: ValentineWeather on April 17, 2016, 11:17:14 PMLooking at the airport I can see its located in a farming area with little concrete and other heat producing structures. I'm in town also but the terrain is so different and much greener so guess your just stuck with what you have. My offset from the airport is usually near 0. On nights when the farmers irrigate their fields, you can SEE the KAVQ RH-numbers climb noticeably.
Quote from: CW2274 on April 18, 2016, 12:26:55 AMQuote from: Old Tele man on April 17, 2016, 11:20:22 PMQuote from: ValentineWeather on April 17, 2016, 11:17:14 PMLooking at the airport I can see its located in a farming area with little concrete and other heat producing structures. I'm in town also but the terrain is so different and much greener so guess your just stuck with what you have. My offset from the airport is usually near 0. On nights when the farmers irrigate their fields, you can SEE the KAVQ RH-numbers climb noticeably.Ha! My console notices when I open the dishwasher to let them air dry from 20' away. Wife has severe nose-bleed problems, so we keep an "indoor mister" running almost all the time in a futile attempt to keep the in-the-house humidity levels above 20%RH, which our current outdoor readings of 5-10%RH definitely do NOT help!
