I have read through the threads but can not find an answer that works on mine. I currently have vws version 15.1 and weatherlink 5.7.1 running on my old system which is windows 7. The davis logger is hooked up with a serial to usb that I bought when I got the software.
I followed the post that said copy my vws folder onto the new computer then install my disk and then copy again. I got a database to big please delete message. I uninstalled everything then copied the folder and installed from the disk. When I open the data is not there. When I try to change the comport to comport three from the default it will not accept anything but port 1
I have taken everything off and am still up and running on the old computer but this is the only thing left I need.
Do I need to install weatherlink before vws or should vws go first? how do I copy my data correctly? How do I get the com port solved.
I appreciate any help that someone may be able to give me. Change is always an adventure
