I forgot to mention this... I have a story to tell... bear with me, grab some firewood too...
When I originally did the mount I fabbed it up in about 20 mins... my neighbor gave me a look and asked if I just put that mount together now? I said yeah, only took a little bit of time and some hardware. (Keep in mind I'm a problem solver, I deal with almost 100 servers at work that like to mess with me, and break for no reason, so I have great troubleshooting skills!)
Anyway I originally used a scrap piece of wood I had in the basement and two pieces of threaded rod I had used when I made a shelf mount that mounted to the back of my LCD TV for my center channel speaker. Later while watching TV with my girlfriend, and marveling at my ingenuity, I realized a critical flaw in my design... The grain of the wood was running sideways on the mount... meaning, with enough force pulling down on the sides, it was possible with enough sun and weather, to split the wood.
I went down into the basement and grabbed another 1ft piece of the scrap 3/4" wood I used for the base, brought it upstairs and proceeded to use two thumbs pressing on it to snap it in two. I immediately called my upstairs neighbor and told him there was a recall on the mount design I used and I'd be up in the morning to replace it with a better version. I went up and loosened the nuts just in case. When I went up to replace it what did I find? It was split, 3/4 of the way through. The only thing holding the two pieces together was the flange for the pipe. Good thing I thought of that and switched the grain direction (which you can sorta see in the first/second pic), the last thing I would want was a smashed Vue on the roof of a pissed off neighbors Prius in the driveway!
