Author Topic: tripod help please  (Read 3374 times)
Offline offroadjosh
  • Davis Vp2 Wireless- VWS 14 P90 Serial Data logger
  • Montana Firefighter
    • My Website=)
tripod help please
« on: February 12, 2009, 01:51:51 PM »
i want to move my anemometer to the roof of my house(when i get the transmitter kit this summer) how would i go about mounting  a tripod up there with out making holes in the roof?
Josh
Josh Patten
Davis VP2 Wireless -May 2008
VWS 14.00P90\WL 5.9.9/Plus others!
Skywarn trained
CoCoRaHS member
Smith Valley Fire Dept Firefighter:)
http://josh.northwestwx.com/station/usa.htm
CWOP-DW0711
Kestrel 2000 hand held anemometer
Cocorahs 4in rain gauge
Custom co
Re: tripod help please
« Reply #1 on: February 12, 2009, 02:26:50 PM »
What kind of roof?  Or use a mount on the gable.  Those sat tv mounts work well.
Offline offroadjosh
    • My Website=)
« Reply #2 on: February 12, 2009, 03:20:10 PM »
umm composite roof(Shingles...) and there is nothing high enough to mount it to
Josh
Josh Patten
Skywarn trained
CoCoRaHS member
CWOP-DW0711
Custom co
« Reply #3 on: February 12, 2009, 03:23:32 PM »
Sorry - you will have to lag bolt it through the shingles.
Offline MoradaWx
  • Marada, Stockton, CA
  • I see sunshine. Let me out!
« Reply #4 on: February 12, 2009, 08:38:23 PM »
predrill your holes and use mastic before you bolt and after
Rick
Rick/Morada, CA
Davis VP2+ wireless w/24Hr fan, Enovoy & Console
VWS 14.01p31,WeatherLink5.9.2,VP live,Virtual VP, StartWatch
Offline Jim18655
« Reply #5 on: February 12, 2009, 09:17:16 PM »
Also, try to screw the lags into the roof rafters or trusses. Just screwing into the roof sheathing will make a weak installation which could get blown over leaving big holes, damaged equipment and damaged shingles where it hits.
Offline mackbig
« Reply #6 on: February 12, 2009, 11:13:37 PM »
that is the one problems with the tripod's, the feet dont line up very well with rafters.  I think I was able to get the single side into one, and maybe one from the double side... but the footprint is does not line up with standard width trusses...
Andrew
« Reply #7 on: February 12, 2009, 11:20:17 PM »
One really needs to build a quadpod.  :)
Offline Scalphunter
« Reply #8 on: February 12, 2009, 11:25:57 PM »
 Well this dumb old indian uses a doubler  when i am fasten  something to my roof. using 2 x 6 or 2 x 8 and  run it  between your rafter. This will spread out the  load and you can nail it to the rafters on each side to  also  add to strengthing your installation.   Mastic above  40 year sealant underneath and in the bolt hole and you will not have any leakage.
john
KL7IFP
Offline offroadjosh
    • My Website=)
« Reply #9 on: February 13, 2009, 12:27:53 AM »
maybe i will look into another way of mounting...
thanks
josh
Josh Patten
Skywarn trained
CoCoRaHS member
CWOP-DW0711
Custom co
Offline f86sabjf
« Reply #10 on: February 13, 2009, 05:45:33 PM »
Thanks for the advice John
knowing the extremes you live in I will heed your advice
acu-rite #825
