I’ve been using a Vantage pro 2 for about 5 year last night the outside temperature jumped from 23⁰C to 70⁰C this was a step change the humidity also dropped from 80 to 30 % this is probably an effect of the temperature change the temperature and humidity had worked ok for the last 5 years. Typically it had to fail on the day before the hottest day ever recorded in my area.
I’ve checked the wiring from the sensor to the transmitter unit and appears to be ok. I’ve removed the sensor and had it in a low humidity room.. But the fault still exists when reconnected. Any suggestions please. I’ve order a Sensirion SHT11 chip to repair it. But before I star removing the old chip I want to make sure it’s faulty and have missed a simple fix. Thanks
