Author Topic: IpTimelapse  (Read 1467 times)
Offline Dane_B
    • WI3X Home Page
IpTimelapse
« on: June 15, 2019, 07:04:41 AM »
Good Morning All:
A quick question. I have been using IpTimelapse software for a number of years. I always used am API key to read my weather station (and another here on Kent Island). Somewhere, somehow something changed. I can no longer read personal weather station info with the newly supplied API key. I can only read airport data and a few other "commercial" stations such as the Annapolis Naval Academy that do not require a key. Am I missing something new with Wunderground? Also, my cams quit showing up on the weather map but that is a "whole nuther can of worms".
Davis Vantage Pro2 Plus
UV and Solar sensors
Remote Wireless Anemometer
http://weather.wi3x.com/gauges-ss.htm
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
Re: IpTimelapse
« Reply #1 on: June 15, 2019, 09:39:06 AM »
I believe it is that IPT has not been updated to accommodate the new WU API key.  I do not know if there are plans to update IPT to change this.
CW3699
Offline SteveFitz1
    • Tyler Texas Weather
Re: IpTimelapse
« Reply #2 on: June 15, 2019, 05:42:49 PM »
A better and easier way to get you weather station data into IPTL is via a text file. If you'll review the discussion here http://www.wxforum.net/index.php?topic=36260.msg372810#msg372810, you'll see my instructions for setting up both IPTL and Cumulus.
Steve
Offline Otis
  • (aka Paul)
Re: IpTimelapse
« Reply #3 on: June 18, 2019, 06:14:37 PM »
So I bit the bullet and moved IPTimelapse to my weather computer so I could use the weather overlay technique that Steve suggested.
After figuring out how to configure Weather Display to create the text file, easy.  As Steve stated, this configuration eliminates having to fetch your own data back from another service.
Here is where the images are displayed. https://www.lakehuronweather.org/wxWebCam.php
Thanks again Steve for the suggestion.
CW3699
Offline Dane_B
    • WI3X Home Page
Re: IpTimelapse
« Reply #4 on: June 18, 2019, 09:38:36 PM »
Steve
Got it. Thanks Steve.
Offline sebeclake
Re: IpTimelapse
« Reply #5 on: December 24, 2019, 10:35:00 AM »
IPTimelapse 2.8 Pro now supports the updated WU API
