All is well with e-rice and my jpgraph folder. One last shot at this. Should the jpgraph files be in it's own folder or copy the files and sub folders to the root? I have tried everything else but continue to get the error that it cannot find the jpgraph files.
See attachment.
Thanks again,
Rickl
You should place
1. the noaa files in the root and
2. the complete jpgraph folder with its two subfolders in the root.
Do not copy the contents to the root, this will give a lot of extra scripts and is not needed at all.
Now your
http://bonairweather.us/jpgraph/ is empty
3. the wxnoaatemps.php And the other scripts in the root
The error is from this line (92) in my version (
http://weather.wildwoodnaturist.com/downloadsCVW.php) of wxnoaatemps.php:
if (!file_exists($jploc."jpgraph.php")) {
$string = "Unable to find JPGraph files";
create_image1($string,$jploc);
exit;
The settings which are wrong are at line 34-35
$loc = "./"; # Set to location of NOAA report files
$jploc = "./jpgraph/" ; # Set to location of jpgraph filesSo if you place the jpgraph folder in the root( and your folder looks like mine) the location for the script which is called by wxnoaatemps.php at line 92 is
from root => jpgraph => src and there the script: jpgraph.php is found
You should change in the wxnoaatemps.php and other scripts the $jploc to:
$jploc = "./jpgraph/src/" ; # Set to location of jpgraph filesSucces, wim
