Author Topic: Has anyone converted or priced Rainwise on converting a Mk III to a LR?  (Read 3171 times)
Offline DaleReid
    • Weather at Eau Claire, WI
I have a nice Mark III regular station that does not have the rain gauge mounted on the whole unit, but does have the adjustable solar collector.  I really would like the improvement of the guts of the transmitter and transmission times from the update, etc.  The wind head, the solar collector, the mounting box, battery, etc. seem identical to both the regular and LR models.
I wonder if a guy could swap the boards and antenna out for an LR at a reduced cost?
Just curious if anyone HAS done this, or if they've ever called Rainwise to ask about price?
Thanks for the comments and this wonderful board I've just discovered!
Dale
http://ECWx.info
Texas Weather WRL-32, Peet Bros Ultimeter 2100, Davis Vantage Pro, Rainwise MkIII, and a bunch of stuff brewing.
ECWx.info
ECWx.info/t/index.php
Offline VaJim
Re: Has anyone converted or priced Rainwise on converting a Mk III to a LR?
« Reply #1 on: February 26, 2012, 08:36:04 PM »
Dale:  I'm not sure about swapping out motherboards, but I did talk to Rainwise about converting my present displays (Oracle and the Multi) and I believe they said they could be converted for about $100 each.
Offline DaleReid
« Reply #2 on: February 26, 2012, 10:16:42 PM »
Thanks, I will try to call them this next week.  The weather will improve soon and I would like to be able to place the system when it becomes nice enough to do so.  I did a chip swap on a multi last year for about $40 or so if I remember right.  It was super easy to do and was on the air getting the LR signal in almost no time.  I understand that the computer interface box is more expensive to update.
Dale
ECWx.info
Offline Feelgood Ranch
    • Feelgood Ranch Weather
« Reply #3 on: February 27, 2012, 10:59:08 AM »
VaJim is correct...socketed chip swap for Oracle and Multidisplay is $100.00/display.  Call Lonnie White @ RainWise for station conversion cost.
Ken Keyes
Ken Keyes
RainWise MkIII-LR, WeatherView 32 v8, StarDotXL 3mp cam, Boltek PCI lightning detector/L2K, CWOP/CW4669, Weather For You
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMTBOZEM2&wuSelect=PWS
http://www.anythingweather.com/current.aspx?id=22721
Offline DaleReid
« Reply #4 on: February 27, 2012, 10:16:44 PM »
Thanks, I think I've talked with Lonnie in the past and will try to connect this week.  Weather's coming!
ECWx.info
