Thank for the reply Wim.
I did as you asked but don't see an error displayed.
The only error I got with a dozen tries was:
PHP parse error: syntax error, unexpected '$domain' (T-VARABLE) in
C:\inetpub\weathercat\WU-History-inc.php on line
1408It is important as that line 1408 is in the changed code and that it is the same line you are referring to
and it is also important that you are using Windows as a website-server.
I did not test the script in a Windows environment yet.
Maybe you could add the debug line just before the
include 'WU-History-inc.php' in wxwuhistory.php
It is now something like:
<?php include_once("WU-History-inc.php"); ?>
change it to
<?php ini_set('display_errors', 'On'); error_reporting(E_ALL);
It is a long shot, but we need an error message about what is happening.
The problem is that this script is working in Saratoga- and Leuven-templates at hundreds of locations without problems.
But I have no list of windows servers using it so I can not compare your site to other windows-sites.
And the addition in the latest version needs an ssl connection. I do not know how to check that on windows.
Probably we have to add some debug code just before line 1408 with the fsockopen to check the used variables first.
Wim
