Hi guys,
I'm a Weatherlink IP user and from when I have upgraded to Weatherlink 2.0 I can't download data by using TCP/IP web download method (see attached screenshot) anymore, while the "local devide ID" method works fine. In particular, when I try to start the download, I receive the message "no new data to download".
Now, the problem is that with web download I had more memory space and so I could make the download occasionally.
Did Davis deactivate this possibility with the 2.0 upgrade, or there is a way to make the web download?
PS the weatherlink software version I use is 6.0.3.
Thank you
