Weather Software > Meteohub/Meteobridge
Reading weather station failed: Connection reset by peer
mthiessen:
Every day or two I get the following in the MB log (System Tab) that starts with "reading weather station failed: Connection reset by peer". Meteobridge works fine and rapid fire is being sent to WeatherUnderground so everything is up and running just fine. I'm just curious if this is a Davis Vantage Pro 2 issue or a Meteobridge issue and if there is possibly some way to fix it.
I'm very pleased with Meteobridge running on a TP Link 3020 and connected to console via WeatherLink IP. I'm looking forward to simplifying the connections when the Nano comes out. Here is the entire log. It seems the rest of the log messages are reporting the process of resetting the connection.
Any idea what is going on?
logger (26.06.2018 11:42:49): reading weather station failed: Connection reset by peer
logger (26.06.2018 11:42:49): disconnect station 0 (Vantage): read failed
logger (26.06.2018 11:43:19): connect station 0 (Vantage via TCP/IP).
logger (26.06.2018 11:43:19): wakeup sent.
logger (26.06.2018 11:43:19): internal logger activated.
logger (26.06.2018 11:43:19): syncing.
logger (26.06.2018 11:43:30): gettime request sent.
logger (26.06.2018 11:43:30): no Vantage time offset.
logger (26.06.2018 11:43:30): eeprom request sent.
logger (26.06.2018 11:43:31): rain collector size 0.01 inch per tick.
logger (26.06.2018 11:43:31): transmitter 1 active as station type (#0) "ISS".
logger (26.06.2018 11:43:31): firmware version request sent.
logger (26.06.2018 11:43:32): firmware version 3.15 (supports LOOP2)
logger (26.06.2018 11:43:32): no reading of Vantage's internal logger.
Mattk:
What is your FW version and WLIP upload interval?
docbee:
Hm, for some reason the TCP connection to the WLIP gets stalled. Hard to say what exactly causes that. Are both units on wired LAN?
Anyway, Meteobridge should just react on that by setting up the connection again, which it seems to do, when I follow the logs...
mthiessen:
Meteobridge 3.6 (Jun 24 2018, build 12226), FW 1.4
Every 5 seconds to WU
mthiessen:
DocBee it is on a wired LAN to the router.
[#] Next page
