Weather Station Hardware > What Weather Station Should I Buy?
Wireless outdoor thermometer
lee331:
Does anyone make a wireless outdoor thermometer that transmits to a small usb receiver with accompanying software
to display periodic readings on a PC desktop ?
Bushman:
CAO Gadgets. Click on the link in my sig below. :)
pfletch101:
Am I correct in believing that these can only be used if you are prepared to let them transmit your data to the cloud, from which you subsequently retrieve it?
miraculon:
A Netatmo might be a possibility. The sender must be located in a 100% shaded area, preferably in a thermometer shelter of some sort. The silver color of the sender will heat up in the sun and give erroneous readings if you don't keep this in mind.
I have an app on my smartphone that can display the readings.
dupreezd:
Lee331,if you are a hands on person and like to tinker, this might be a solution
http://www.instructables.com/id/Arduino-IOT-Temperature-and-Humidity-With-ESP8266-/
[#] Next page
