Miscellaneous Debris => Tech Corner => Topic started by: PaulMy on December 11, 2017, 06:37:29 PM
I am on my final step in the change to Godaddy cPanel hosting. I am having trouble with the export/import of MySQL database, as it didn't do a full export. Export stopped after 2,030,846 data lines. The import (which I did before realizing the export was not complete) has even less data lines in the new database. I am using notepad++ to check the file.
I then did a database backup and is larger so this may have included the whole database/tables but it is too big to open in Notepad++
What could I use to open that large of a .sql file so I can check if it is a complete and current backup?
Hi Paul,
I use MAMP but you could use WAMP or similar and set up a localhost. Good for testing.
Backup your database then you can import it to your localhost and check it there.
Hope it helps
Thank's Colin, I still can't open the full backup on my computer but at GoDaddy's suggestion i exported one table at a time and then imported in single tables in the new cPanel hosting, and that was succesful.
All my import updates are now working again and only lost some short term data while I was exporting and importing.
I think I am done with the upgrade, and next is moving to PHP 7x which I can now do with spaniel hosting.
