Thanks for the WU heads-up.. I see mine is working again. They must have fixed the WU site to (re)support their released Google Widget code.
Arthurhh, yes, my wife, MIL, BIL are going to New Zealand for a cruise from Auckland down the North and South Islands, over to Tasmania, then two stops in Australia, ending in Sydney. I'd love to meet folks in NZ for coffee/chat as we make stops in various ports
For your local mesomap, there are multiple options, each with pros/cons and degree of difficulty in customizing it.
Easiest is to add the WeatherUnderground Google Widget to your website.. virtually no customization needed (except to set the map center point and zoom level). Con: only shows temperature (and wind-barb on temperature), no 'rotating conditions'
Second easiest is to use MesoMapLive with WD .. it is a Flash control, and you do need to subscribe to the MML feed for data, but it's easy to customize and presents a nice animated display with mouse-over features. Does cost for license (1 time) and yearly subscription to the feed but is inexpensive.
Third is to join the NZ weather network (if you aren't already joined) .. you can then offer the PHP version of the NZWN mesomap with rotating conditions and all.
Fourth is to take the NZWN mesomap display code and modify the control file and map to suit your needs .. its by far the most complicated option and will take a good bit to accomplish (I know because I wrote the mesomap and caching programs for the regional networks).
So.. hope this helps,
Best regards,
Ken
