Author Topic: Spring/Summer '18  (Read 25756 times)
Re: Spring/Summer '18
« Reply #50 on: April 04, 2018, 01:29:31 PM »
Other record lows around Nebraska this morning.
Offline DRoberts
« Reply #51 on: April 04, 2018, 04:07:36 PM »
Close to a 50 degree range min to max today. Low this morning 14, current temp 62. Wind gusts to 35.
ValentineWeather, you have snow in your forecast for Friday?
Going  to plant iceberg lettuce, Yukon gold potatoes, snow peas, and icicle radishes for my garden this year. ;-)
« Reply #52 on: April 04, 2018, 05:21:45 PM »
We do...
Offline WeatherHost
« Reply #53 on: April 05, 2018, 06:34:27 AM »
A Winter Storm Watch is in effect Friday night through early Saturday morning. Moderate to heavy wet snow is possible in the Watch area. It is still too soon to detail specific snowfall amounts. However, up to 4 inches will be possible, with isolated higher amounts not out of the question.
« Reply #54 on: April 05, 2018, 08:13:25 AM »
Low of 13 this morning. Twins game will be the coldest opening day since 1962. When played outdoors.
3:00 start. MLB is stupid.
« Reply #55 on: April 05, 2018, 12:09:47 PM »
UGH
« Reply #56 on: April 05, 2018, 03:51:01 PM »
Chance for some record cold here too. Forecast is calling for 10° on Sat. but they are almost always on warm side after arctic front. To Break record it will need drop down to 5° again so may be pushing it.
I'm looking at the RAP models for tonights snow most I'm seeing with afternoon runs is 1-2". So without a little deeper snowpack may not reach 5° necessary for record Saturday morning  :sad:...
« Last Edit: April 05, 2018, 03:59:19 PM by ValentineWeather »
Offline DRoberts
« Reply #57 on: April 05, 2018, 05:34:12 PM »
Pretty chilly for this time of year. Not enough snow to help with the dry either. [ You are not allowed to view attachments ]
« Reply #58 on: April 05, 2018, 06:29:48 PM »
That means single digit wind chills.
Offline WeatherHost
« Reply #59 on: April 06, 2018, 03:48:54 AM »
With a mere 5 days on the clock, we're almost 8 degrees below normal for the month to date.  The next several days, maybe a week, also look to be well below normal.  After that, maybe a flip.  I've seen moths previously that started out far below (or above ) normal that ended the opposite, so we'll see how this one works out.  We went something like 15 or 16 months straight above normal before breaking the streak with one below normal month.  Since then, it has been a mix.
« Reply #60 on: April 06, 2018, 09:21:46 AM »
From the Farmer's Almanac:
After the snow the past 3 days, maybe I'll become a believer...
April 2018 Long Range Weather Forecast for Southern Ontario
DatesWeather Conditions
Apr 1-6Snow showers, cold
Apr 7-12Sunny, turning mild
Apr 13-16A few showers, warm
Apr 17-20Sunny, cool
Apr 21-24Rainy east, sunny west; cool
Apr 25-30Rainy periods, cool
Apriltemperature 5°C (avg.)
precipitation 40mm (20mm below avg. east, avg. west)
« Reply #61 on: April 06, 2018, 10:28:16 PM »
Another freeze warning has been issued for tonight.  But this time snow is expected, projected at a half an inch.
« Reply #62 on: April 07, 2018, 06:07:28 AM »
WINTER WEATHER ADVISORY
Areas Affected:
 Beckham - Blaine - Caddo - Canadian - Carter - Cleveland - Coal - Comanche - Custer - Dewey - Ellis - Garvin - Grady - Greer - Harper - Hughes - Johnston - Kingfisher - Kiowa - Lincoln - Logan - Major - McClain - Murray - Oklahoma - Payne - Pontotoc - Pottawatomie - Roger Mills - Seminole - Stephens - Washita - Woodward
Effective: Sat, 4/7 3:28am Updated: Sat, 4/7 5:00am Urgency: Expected
Expires: Sat, 4/7 12:00pm Severity: Minor Certainty: Likely
Details: ...WINTER WEATHER ADVISORY IN EFFECT UNTIL NOON CDT TODAY...
* WHAT...Sleet, freezing drizzle, and snow will result in a light
glaze of ice causing some slick spots on roads. Some locations
within the advisory could receive up to an inch of snow
accumulation.
* WHERE...Portions of central, east central, northwest,
southeast, southern, southwest and western Oklahoma.
* WHEN...Until noon CDT today.
* ADDITIONAL DETAILS...Plan on slippery road conditions. Be
prepared for reduced visibilities at times.
Information: A Winter Weather Advisory means that periods of snow, sleet or
freezing rain will cause travel difficulties. Be prepared for
slippery roads and limited visibilities, and use caution while
driving. The latest road conditions for Oklahoma can be obtained
by calling 8 4 4 4 6 5 4 9 9 7, or for Texas by calling
8 0 0 4 5 2 9 2 9 2.
Offline WeatherHost
« Reply #63 on: April 07, 2018, 06:39:33 AM »
You think it's odd, but then you look back through the records and find it really isn't.  Records show we've had snow as late as April 18 (1/2" 1983) and freezing temperatures as late as May 7.  I also see a 34 on May 27, 1961
The record low for today is 24, but I'm not sure we'll hit that.  Record snowfall for today is T 1982 and we've already beat that - ground is white.
Offline WeatherHost
« Reply #64 on: April 07, 2018, 07:27:25 AM »
Yes, that date stamp say April even if nothing else in the picture does.  Well, the peach tree is trying to bloom, so there is that.  Not expecting peaches though.
Offline DRoberts
« Reply #65 on: April 07, 2018, 08:47:26 AM »
Official site at the airport, 6 miles from me, is 5 above. Next county seat east, 2 above.
Never seen anything like this so late in the year. An inch of snow on the ground.
« Reply #66 on: April 07, 2018, 12:24:41 PM »
You were colder than Cherry County northern Nebraska then. 3 thermometers around here were 8,9,10°. I think some of the colder core air from system has went south as the storm moved.
« Reply #67 on: April 08, 2018, 11:58:00 AM »
Good News its finally over.
Winter has been booked on charges of Loitering, Trespassing, and Obstruction of Spring.
Offline WeatherHost
« Reply #68 on: April 08, 2018, 12:50:01 PM »
I've often said that April 15th is the Season change, no matter what NWS or the stars say.  Thursday is the 12th and that appears to begins a string of 70 degree days.  OK, so I was off by 3 days this year.
« Reply #69 on: April 08, 2018, 04:25:11 PM »
I think you have tax day confused with end of winter.  :-k At no time ever have I remotely considered middle of April being the end of winter.
Even here sprinklers are normally being readied, grass is greening up some even mowed during the Masters Tournament weekend.
This year totally different with temps running almost 20° below normal but more normal 60's on horizon.
« Reply #70 on: April 08, 2018, 04:28:46 PM »
-19.6° currently.
« Reply #71 on: April 08, 2018, 04:34:55 PM »
lightly snowing and about 25-30 degrees below normal.
« Reply #72 on: April 08, 2018, 04:36:26 PM »
By Wed., pushin' 100F........ :roll:
« Reply #73 on: April 08, 2018, 05:50:55 PM »
Send a chunk of that our way and leave a bunch in Colorado...Please
Starting to worry about upcoming wedding trip Arizona/Vegas going across the rockies. Been stuck in blizzards more than once on those hills.
« Last Edit: April 08, 2018, 05:53:05 PM by ValentineWeather »
« Reply #74 on: April 08, 2018, 06:23:27 PM »
Our average first 100F is late May. Bright side, at least this should hopefully start to kill off some of the damn pollen. ](*,)
