I'm mostly a small time lurker here and have owned an Acurite 01010 weather station for almost 3 years. I've always found it a bit hard to read but has done an fairly admiral job. My brother and I both received the new 01036 weather stations for Christmas from our wives. I there when he opened his up and even though he's retired, like me, he was like a kid on Christmas morning, he's had a 01515 for a couple years and he hasn't had as good a luck with his as I have with 01010, one wind cup got broke off and one other function stopped working.
Anyway his display worked but would only stay lit for about 2 seconds even when connected to the power supply. He called Tech. support Thursday and they're sending him a new display in about a month, they're backordered. My display will not power up at all batteries or otherwise. I checked the batteries one at time, all new BTW, and they are fine. I checked the power supply and it's putting out 6.7 volts, my brothers is putting out 6.5 volts, it's rated at 4.5V, seems a bit high to me. Anyway my current 01010 station only needs an ambient temperature fan, seems to have bad bearings, so for around $22 for the single solar panel or $35 for the new dual solar panel replacement I should be back in business. I would like to keep my old one as it was a Father's Day gift from my two sons one of which has since passed away and it was the last 'physical' gift I received from him, I'm sure you folks understand why I'd like to keep the old one going. My plan was to position the older unit near my woodworking shed and put the new one where the old one is. Now that I know of at least two bad units right out of the box I'm thinking of sending the entire weather station back for a refund. It seems they may have a manufacturing problem. I searched the forum for 01036 and didn't find anything. What's the consensus on these new color units on here?
I've been a Weather Buff since I was old enough to write and that was quite a while ago. I'll try to get around doing a member introduction soon.
