Author Topic: Ken's Template  (Read 3456 times)
Offline DaculaWeather
    • North Georgia Weather
Ken's Template
« on: December 12, 2015, 06:06:56 AM »
I was going to try out Ken's USA template for WD, a school I work with got a $3000 grant for a weather station, webcam, and lightning detection system, and I'm going to help them get setup.
I had an old version of the template running on a placeholder domain I have... up until yesterday. I thought I would re-download all of the new template and start over. Great idea you say? :-) Only if it worked. :-)
I've started over several times now to get rid of an error I'm getting and I can't figure out why I'm getting it. First, I will not be using any language other than English, and no CSS swap.
The error I get when I try to go to the page is" "Parse error: syntax error, unexpected T_FUNCTION in /hsphere/local/home/bruecksteve/gwinnettweather.com/common.php on line 95"
The website is here: http://www.gwinnettweather.com/
Right now, everything in the files should be generic and the way it came in the template, but I'm obviously missing something. I had made changes that didn't work, so I re-extracted all the files again and re-uploaded. I'm sure it's probably something stupid..
Thanks in advance!
Offline Maumelle Weather
    • Maumelle Weather
Re: Ken's Template
« Reply #1 on: December 12, 2015, 06:38:15 AM »
Hi Steve,
I believe I came across this error before and the only way I could get rid of it was to remove the words "langtrans" and "langtransstr" from the PHP functions in the various files, but I won't swear on it. That's been a couple of years ago. I had made sure the language settings in Settings.php were set to false, etc. and was still receiving the error.
Hope that helps, although I'm not sure at this hour.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
Re: Ken's Template
« Reply #2 on: December 12, 2015, 06:38:47 AM »
Are you upgraded to the latest version of PHP 5+? I had this same problem thinking the server i had was 5+.. until he upgraded.
« Last Edit: December 12, 2015, 06:40:42 AM by mkutche »
Mike K.
Gosport, Indiana
Re: Ken's Template
« Reply #3 on: December 12, 2015, 06:39:21 AM »
Thanks John... My old common files had all of that removed as well.
Re: Ken's Template
« Reply #4 on: December 12, 2015, 06:43:07 AM »
Quoted the wrong post! :-)
Yes, 5.2.17
Offline mkutche
    • GosportWx.com
Re: Ken's Template
« Reply #5 on: December 12, 2015, 06:45:48 AM »
Yes, 5.2.17
Try 5.4.45 that's what I use, otherwise I'm not sure how to fix it.
Mike K.
Gosport, Indiana
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Ken's Template
« Reply #6 on: December 12, 2015, 10:14:39 AM »
Could you attach the PHP that is causing this? Just by looking at the error there is not much I can do to try to help you because I need to see how the error was generated. Just see if you can attach the actual script, or any other scripts that it "includes" and contain functions referenced by this script.
Re: Ken's Template
« Reply #7 on: December 12, 2015, 10:32:32 AM »
It's the statement
      $text = preg_replace_callback('!\.\s+([a-z])!s',
  function ($matches) { return('.  ' . strtoupper($matches[1]) ); }
  ,$text);
that causes the issue.  That was done (where a /e PCRE_modifier on the regex used to be)
e (PREG_REPLACE_EVAL)
Warning
This feature has been DEPRECATED as of PHP 5.5.0 and REMOVED as of PHP 7.0.0.
The use of an anonymous callback function was enabled in PHP 5.3, so your PHP version must be 5.3 or above.
PHP 5.2.17 also had some annoying issues with JSON decoding which affected the quake-json.php and WU-forecast scripts.
So... you have to use a PHP version of 5.3+ to run the template now...
Re: Ken's Template
« Reply #8 on: December 12, 2015, 10:34:23 AM »
Great... let's see if the hosting people want to do that. :-)
Re: Ken's Template
« Reply #9 on: December 12, 2015, 10:35:48 AM »
Most hosters offer an option (either by cPanel or .htaccess entry) to specify the PHP handler version..
Offline virusdunil
    • Station Meteo Hebertville
Re: Ken's Template
« Reply #10 on: December 12, 2015, 10:48:25 AM »
just for the fun of it,ive just chekcked mine (Rapidenet) via DirectAdmin/Select php version  and the choices are from 5.1 to 5.6
Cabled Vantage pro2 + Solar / Stevensen screen
Weather Display latest version + Boltek PCI-NexStorm-StormVue NGX / NSDisplay
http://www.meteolacstjean.com/weather28/index.php
Meteotemplate : http://www.meteolacstjean.com/hebert/index.php
Offline Jáchym
    • Meteotemplate
Re: Ken's Template
« Reply #11 on: December 12, 2015, 10:59:13 AM »
I would say that 5.4 is the standard today, it has been around for quite some time, has been tested thoroughly and I seriously doubt your hosting provider did not offer this or at least the 5.4 version. Especially the change from 5.2 to 5.3 brought some important new functions. My template is also compatible with only versions 5.3 or higher and even 5.3 was problematic and I had to make some changes after I first released it because I myself use 5.4. Btw., version 7 is just behind the corner :D
Also, I recommended upgrading to several of the Meteotemplate users and there was never a single problem associated with the change - other than it started working as it should :-)
So in case you have to option to upgrade (which I am 99% sure you will have), then I would personally go for 5.4 or maybe even 5.6.
Re: Ken's Template
« Reply #12 on: December 12, 2015, 03:18:16 PM »
I'm at 5.3.29 now and it's working. Guess I need to do my other domains as well.
Thanks Ken!
Re: Ken's Template
« Reply #13 on: December 12, 2015, 04:36:18 PM »
Ken, one more question. Why am I getting this in place of the dashboard?
"Note: ajax-dashboard not included since weather station not yet specified."
Not sure where it's looking for that. I am reading the testtags file with no issue.
Offline mkutche
    • GosportWx.com
Re: Ken's Template
« Reply #14 on: December 12, 2015, 05:19:09 PM »
Thanks Ken!
Glad it's working :) yw
Mike K.
Gosport, Indiana
Re: Ken's Template
« Reply #15 on: December 12, 2015, 06:37:08 PM »
That's the message shown on wxindex.php (and some other pages) if no Settings-weather.php is on the website .. that's the file that determines what tags/dashboard/etc. to use based on the weather station.  The Settings-weather.php is in the *-plugin.zip distributions, and all those files have to be uploaded for the template to work correctly with a given weather software program.
Offline CNYWeather
    • CNYWeather
Re: Ken's Template
« Reply #16 on: December 12, 2015, 06:42:26 PM »
Looking good Steve. How many fancy webcams you going to get?  :-)
Tony
Re: Ken's Template
« Reply #17 on: December 12, 2015, 07:13:40 PM »
The file is up there Ken.
Re: Ken's Template
« Reply #18 on: December 12, 2015, 09:22:01 PM »
The site I'm having trouble with... none. Actually, it will have my webcams on it, but no new ones. The school site will have one.
Re: Ken's Template
« Reply #19 on: December 12, 2015, 09:27:39 PM »
Fixed. I was missing a section in the Settings-weather file
