Author Topic: Adding Weather Almanac to Website  (Read 2402 times)
Offline Gruve5
    • Gruver Weather Service
« on: April 07, 2011, 03:36:23 PM »
What would be the easiest way to add a Weather Almanac to my website.  I would like Normal Temps and Record Highs & Lows and have it change everyday.
« Last Edit: April 07, 2011, 03:38:53 PM by Gruve5 »
Offline diego45
    • ClimaSurGBA
Re: Adding Weather Almanac to Website
« Reply #1 on: April 07, 2011, 03:39:38 PM »
Murry Conarroe from Wildwood Weather has done a script for that. I Think that's what you need...
Offline Gruve5
« Reply #2 on: April 07, 2011, 05:02:42 PM »
Any idea where I could find it?
Offline kray1000
  • Purveyor of wry
« Reply #3 on: April 07, 2011, 06:27:09 PM »
It looks like you're using VWS.  If so, here's a template you may be able to modify for your use.  Add that file to your list of HTML Files (Internet menu in VWS) and add the corresponding cities to your Climate Report (Wunderground menu).
Here's what it looks like on my site.
Offline Gruve5
« Reply #4 on: April 08, 2011, 05:08:38 PM »
So this may be a stupid question, but do I need to create an additional page on my website like yours to make this work or can I do a small section on the front page of mine?  If so, how do I direct the stats to be updated from VWS to the front page of my website?
Offline kray1000
  • Purveyor of wry
« Reply #5 on: April 08, 2011, 07:31:48 PM »
You can do it either way.  If you want it to be a small section within your index page, add the tags to that page, process through VWS the same way your existing usa.htx file is being updated, and upload it to your site.
Offline AWL
    • Ardmore Weather Live
« Reply #6 on: April 08, 2011, 07:35:36 PM »
How do set up a 'climate report' on Wunderground? Looked around and I can't seem to find how to do that.
Thanks, Doug
Really like your 'Area Almanac' page
« Last Edit: April 08, 2011, 07:41:39 PM by DougW »
Offline kray1000
  • Purveyor of wry
« Reply #7 on: April 08, 2011, 08:05:34 PM »
In VWS, click on the "Wunderground" menu, then "Climate Report".  Fill in the city and states you would like to include.
Offline AWL
« Reply #8 on: April 08, 2011, 08:13:59 PM »
Thanks for the reply. I see now! I run WD. Was thinking you were refering to WeatherUnderground and a report that could be generated. Sorry!
Thanks again, Doug
Offline kray1000
  • Purveyor of wry
« Reply #9 on: April 08, 2011, 08:19:51 PM »
Sorry, I saw the current conditions page for Montgomery and assumed it was yours.  Maybe this will be helpful to someone else.
