When you say:
"Atlas Display says: 40°
My Acurite says: 64°"
Do you mean the Atlas display says 40°, but the Atlas Array says 64°? Is that the same unit, Or is the 64° coming from an older AcuRite 5-n-1?
Both reading are from the Atlas. My 5-in-1 currently is not mounted and has no batteries; I may mount the 5-in-1 again as a second station but I do not have a pole right now.
The signal strength is good. It did say the batteries were low; they were new when I got the atlas. I checked them just now and they were at 1.4v. I put in new ones, measured them first and those are at 1.6v. The display no longer indicates low batteries. Swapping batteries did cause a false lightning strike.
So I'll keep an eye on it for the next few days. Right now both Myacurite and the display show 67°. The stand alone says 71°. The stand alone is in the shade though; so I can what the difference is between sun and shade temps.
The forecast on the display is not to good. Ever since I've had the Atlas, the display has mostly has said rain. I live in California, we haven't had rain since April 19th. I know the unit takes time to learn but how much time does it take? The forecast on the app seems to jive with the local forecast.
