New to acurite products. I bought a 5n1 from Costco and signed up to myacurite.com and I noticed that my outdoor sensor (06002RM/592TXR) is reading pressure along with temp and humidity. I was not expecting pressure. It seems to be slightly different readings than my 5n1 sensor. Does the tower sensor have a barometer?
No. The tower sensor does not have a barometer. The barometer is in the bridge/SmartHUB.
Your 5n1 doesn't have a baro sensor, either. It's actually in the display. Every Acurite display has its own. That's one reason you'll notice differences.
In the original MBW protocol, the 13 raw barometric parameters were sent from a baro sensor in the bridge in a separate http statement. This was because the firmware did not have the math code to process the baro information, so it handed everything off the the MBW servers for further processing. This was scheduled to happen every minute.
This changed in the myAcurite protocol. The firmware in the bridge was updated to be a "SmartHUB". It now has the ability to process the raw baro parameters into a single number representing either station or altimeter pressure.
This cut out a whole line of http messaging in the new protocol. However, the barometer value still needed to be sent, so it was just tacked on to the other http messages from the other sensors.
