Author Topic: Measuring wind speed  (Read 2999 times)
Offline J Lunis
« on: October 28, 2015, 07:54:36 AM »
Have a WMR200A.  FINALLY got around to setting up the anemometer.  Been in service for a couple of months. My problem is the indicated wind speed.  WAY off.  On AnywhereWeather screen, the wind speed hx shows a range or 0.0 to 0.3 MPH.  Never higher. Today, for example, we are having wind gusts of 25-30 MPH.  Sustained winds of 8-10 MPH.  Hx on AnywhereWeather shows Max gust of 2.9 and wind speed a little below 0.2.  I've never seen a Max gust higher than 3.4 MPH.  I can see the unit and it spins quite fast WITHOUT wind gusts.  How can I get wind speed to measure accurately?
And a bonus.  In searching for an answer here I found a reference to having a battery pack mounted to the wind sensor by cable.  Where can I find how to do this?
Offline Scalphunter
Re: Measuring wind speed
« Reply #1 on: November 01, 2015, 06:27:31 AM »
In back of the solar panel is an NiCad battery pack.  What software are you using sounds like it might not be set upright
Offline J Lunis
« Reply #2 on: November 01, 2015, 07:56:03 AM »
OSanywhereweather
I found the battery pack.  How do I run a cable between it and the anemometer?  If easier, just provide a link.
Offline Scalphunter
« Reply #3 on: November 15, 2015, 11:09:00 PM »
should be 2 cables there from it one to the  wind  and other to the thermometer
Offline J Lunis
« Reply #4 on: November 16, 2015, 09:53:53 AM »
Thx for the reply.  I can find the battery pack(?) in the solar panel. Searched the manual for "cable' and got 2 hits - USB cable and solar panel cable.  I see cables? connected to the solar panel.  How do I run a cable from the solar panel battery pack to the anemometer?  It's probably in the manual, but I can't find it.
Offline J Lunis
« Reply #5 on: November 19, 2015, 02:54:53 PM »
OK, I'm about to give up.  Played with OSanywhereweather for several days (not ALL day).  Reset devices.  Fresh batteries.  Uninstall/reinstall sw.  Still get incorrect wind speed.  Everything else perfect.  Gave up and installed Weather OS Pro.  I can find no instructions in HELP telling me how to connect WMR200A to sw.  Google search reveals nothing.  Where can I find instructions to connect my device to the PC/SW (wireless)?  BTW, not locked in to Weather OS/Pro but it seems to have some advocates here.
Offline wa2slh
« Reply #6 on: December 02, 2015, 10:45:34 AM »
Try Cumulus. It works great.
Offline J Lunis
« Reply #7 on: December 04, 2015, 08:44:13 AM »
OK, my bad.  My preference is sw that allows me to view current weather conditions from my cell, regardless of my location (500 miles away).  I do not see Cumulus has that capability.  What sw, other than osanywhereweather has that capability?
Offline George Richardson
    • Smith Mountain Lake Weather
« Reply #8 on: December 04, 2015, 11:11:45 AM »
J Lunis,
FWIW, this is a Cumulus web site template: http://www.smlweather.com/cumulus/index.htm .
Offline J Lunis
« Reply #9 on: December 04, 2015, 11:14:18 AM »
Yeah, I read the data on Cumulus before I dl'd it.  Maybe I'm missing it, I see nothing on sending data to a cell phone or over the net.  Am I missing something?
Offline mcrossley
    • Wilmslow Astro
« Reply #10 on: December 04, 2015, 11:22:56 AM »
Cumulus can upload to a web server, it includes the basic template as shown above, and there other third party templates available. There are also a few third party phone apps for it such as this one... Weather Station for Cumulus
Offline J Lunis
« Reply #11 on: December 04, 2015, 03:03:56 PM »
Thanks for the help.
I'm not certain I know the proper way to ask this.  To connect the WMR200A base to the PC requires a long run and installing one outlet? box on each side of one wall.  Is there a WMR200A display (same data as the base station) I can put in one room and put the base by the PC?
