I was thinking that anything you use might be better brushed on vs. sprayed on. If any of the spray particles enter the SHT15's sensor opening that could ruin it. Maybe if you have a Radio Shack or that type of electronics store around they could help provide you with something.
after thought: You may want to try whatever you use on a test piece of material, let it dry thoroughly, and check it for any continuity with an ohm meter set high.
