As George Nincehelser said, I bought the dual panel top to eliminate the 9:00 am and 6:00 pm temp spikes - smooth the curve - and, for a short while, it did that. After a couple of months, the spikes came back but instead of lasting 30 mins. or so as they did with the single panel, they would remain for several hours and temperatures would climb so high (10-15 degrees compared to any station within miles and even my tower sensor) that I'd get booted from WUG almost every day.
The problem is inertia - it simply takes the dual panel fan much longer to start, especially in the mornings when the sun is not fully bright or it's behind passing clouds, than it does the single panel fan. Once it starts, it's fine and will keep running. It does not take much to get it going...the barest little nudge will do it but, for whatever reason, it needs that nudge. So, I don't think it's a fan speed problem. In my case, at least, the spikes occur because the fan is not running at all during those "spike times."
I have put my old single panel top back on the sensor and, for the time being, I will live with it.
