Since I have all the parts, I thought that I would lash up the mini-circuits amp and see what I get.
It was a very humid morning, foggy and condensation all over everything. A good worst case test for my wet foliage issue.
At first I put the BPF at the input and the 50 Ohm terminator and tee at the output of the mini-circuits amp. That is a ZFL-1000GH as you will recall from the last exciting episode..
I ran a N-male to SMA-male jumper to the BPF, and a SMA-male to RP-TNC at the Davis RF-IN cable. The mini-circuits amp has SMA-female connectors for both input and output.
Nada. OK, maybe things are just too wet and the signal is so low that the gain can't make up for it.
I tried with and without the BPF, the 2dB attenuator instead of the terminator with no luck. I came down to the basement to watch the "compass rose" RSSI indicator and it was "all dashes".
Finally out of desperation, I removed everything that has any kind of attenuation. Removed the BPF with its 2.5dB insertion loss, and put the 50Ohm terminator back on. Still no luck. Red blinking status LED out on the repeater, no synch on the console.
I then remembered that there was some gain dependence of the ZFL-1000GH with power supply voltage. I was running it on a regulated 13.5V supply. The gain difference at 925.40MHz between 12V and 15V is substantial, 27.20dB at 12V and 31.88dB at 15V. I brought up the Marlin P. Jones bench supply and set it to 15V. Watched it for a while and saw some different patterns on the status LED, pausing off for a while. All of a sudden green blinkage occurred!
Apparently, the gain is critical and the stack-up of the 2.5dB in the BPF and probably another good 2dB due to the supply voltage hurt the cause significantly. Adding the 2dB attenuator was insult to injury.
So, I am still mulling on whether to make the final leap with the 17dBi antenna or not, but I am going to run this gain configuration once my enclosure (a Davis transmitter back housing and spare plain hinged cover) and the 15V power supply arrives from Mouser.
Here are the "DIP 4 Test Mode" RSSI readings in the compass rose. According to Davis the desired range is 30-60 (DAU, Davis Arbitrary Units). This is the true "as received" signal strength (normalized to the Davis funny units). Note that I ran the no-amp case afterwards, so any improving conditions due to the foliage would not bias the test favoring the amplifier. (it was clearing and drying up during the afternoon)
With the 14dBi antenna only:
Ranging from
22-26 typically around 25 DAU. (out of 60)
With the full treatment, 15V supply, ZFL-1000GH, 50Ohm terminator, no BPF:
Ranging from
38-40 typically 40 DAU. I did see a brief dip to 32 once, but wasn't typical.
After I found the right "recipe", it did 'move the needle' by about 10-15 DAU. While it remains to be seen whether this really takes care of most of the "wet foliage" issue, it seems that it should give some more margin and reduce the probability of loss of signal. Still not sure about the bigger antenna, the 17dBi is about twice as long. I'll leave space for it's larger bracket, just in case.
