Author Topic: Best way to take off flux  (Read 951 times)
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« on: June 14, 2014, 08:45:39 AM »
I got some extra flux on a board what is a easy and safe way to clean it up?
Anthony
Offline Jumpin Joe
    • Joe’s Weather
Re: Best way to take off flux
« Reply #1 on: June 14, 2014, 08:54:26 AM »
I use "Flux Off". It works great. I think I ordered it from Amazon or Mouser.
Joe
https://joesweather.info
WeatherLink Live
Offline wxtech
    • Lexington, Ga. Weather
« Reply #2 on: June 14, 2014, 08:54:57 AM »
alcohol on a Q tip or small brush
nail polish remover is mostly acetone, that'll work.
If the flux is thick, it'll be brittle and you can chip it off with a sharp soldering aid.
« Last Edit: June 14, 2014, 08:58:10 AM by wxtech »
  • Hi there!
« Reply #3 on: June 14, 2014, 01:01:54 PM »
Thank you both!
Anthony
Offline W3DRM
    • Emmett Weather
« Reply #4 on: June 14, 2014, 01:35:55 PM »
Just be certain that you do not get any of the alcohol or other liquids in the buzzer on the controller board as it will most likely ruin it.
--- RIPE Atlas Probe - 32849
Offline wxtech
« Reply #5 on: June 14, 2014, 02:16:12 PM »
More soldering information is here:
http://www.lexingtonwx.com/html/soldering.html
« Reply #6 on: June 14, 2014, 02:42:12 PM »
Joe
I also used "Flux Off" with the built-in brush. You can scrub the board while you are spraying.
http://www.mcmelectronics.com/product/20-1960
Greg H
