I dont know what type of fans are in these FARS or what voltage.
On a three wire fan, the third wire is the tach or fan speed and on a standard computer fan sends out two pulses per revolution. The ouput is an open collector and needs an external pullup resister which allows for various configuration uses.
I wanted to see if a fan was turning without having to listen if I could hear it spinning. I used a LED and resistor and connected the LED and a load resistor between power and the tach wire.
If you can get a three wire computer fan which is replacement for your fan (size, voltage and current drawn), this might work for you as well. Just check if the LED is on. If the LED is dim, the fan is spinning slowly.
